Cell Phones Logo
A
Anonymous Posted on Jul 24, 2014
My LG Extravert froze so I took the battery out for a while and now everytime I try to turn it on, it just freezes on the LG screen. How can I fix that?
abdullah
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jul 24, 2014
abdullah
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
1029
Points
27
Try resetting everything or connecting the phone to your pc and download lg's softwareon your computer and then format it
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jan 03, 2009
SOURCE: LG rumor turns on then freezes
well, you could try to turn it off for a night and then you could see if it works or you could go to the sprint store and ask them and they will give you a new phone if there is not any damage
Anonymous
  • Posted on Aug 14, 2009
SOURCE: my lg rumour 2 won't turn on. it froze so i took
I'm on my 2nd rumour 2. Both now the camera has froze the phone where i have to take the battery out. Ive returned one, and now Im about to return the second one. Anyone else had this problem?
Anonymous
  • 10 Answers
  • Posted on Aug 29, 2009
SOURCE: my LG lotus won't turn on.
Mine started doing the same thing yesterday. In doing a bit of research I found on the LG support forums that the phone is probably fried. The good news is that it's covered under the 1 year manufacturers warrenty and can be returned to the sprint store, or your carrier and they will replace it on site. I've already talked to Sprint and they said as long as there's no water damage or other visable signs of shock that would have caused the damage that they'll provide me with a new phone. This was a huge relief to me, I loved this phone before it went batty and really can't afford a new one.
Hope it works out for you as well.
Anonymous
  • 78 Answers
  • Posted on Feb 16, 2010
SOURCE: LG Arena screen freezes on LG loading screen and won't turn on
charge ur mobile fully and switch it on. it will take a long time to load. take patience and wait for and hour or two. then when u gain access to the memory, remember what was the last application or file u used. if that it was big or untrustworthy delete it.
Anonymous
  • Posted on Feb 20, 2010
SOURCE: My LG Lotus when i turn it on stays on the
Ugh. The same exact thing happened to mine. I am so incredibly angry and frustrated! I heard that trying a new battery might work... I tried my sister's battery, since she has the same phone, and it was no go for me, but you ought to give it a try if you can... I did everything I could to try and fix it, but it won't do anything else!
How can i replace an LCD Screen Display a verizon LG extravert VN271?
Here's a video showing you how to take the phone apart: How to take apart lg phone It's not very professional, but you can use it anyway. Here's a replacement outer screen: Original OEM Verizon LG Extravert VN271 Outer Glass Front Digitizer... Lastly, here is the inner screen: Verizon LG Extravert VN271 LCD Display Screen Replacement Part Parts... Good luck!
3helpful
My LG Lotus when i turn it on stays on the original LG LOTUS screen and freezes, any ideas on how to fix it? i was text messaging and my phone froze and shut off. when i turned it back on it stayed...
My LG Prada KE850 seems to be frozen, will not go to main screen!
2helpful
My sansa fuze froze when I took ou the MicroSD
when switched off,plug in the MicroSD again and let it startup...if it starts up well and good...turn it off and only then remove the microsd..the try turning it on...
My env2 just randonly froze one day and when i turn it back on it
I took my env2 to a verizon store that also performs repairs and they did a new software download on my phone and the freezing has stopped. They said there was a software glitch when they first came out and its a download they will do for you for free..takes about 45 minutes and now i have no problems.
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
90helpful
18answers
LG Rumor Phone's screen frozen
If you have a memory card in the phone...take it out. then turn take out the battery. Turn it back on. And if that works. its because you have a virus and or corrupted file on that memory card. Same thing happened to me. But now the screen is all messed up everytime i slide it open or closed.
My phone keeps freezing...
my phone froze and i attenpted to turn it off several times, after trying and not getting a response i took out the battery pack and placed it back in and turned the phone back on. after turning the phone back on it kept freezing a
My razr....
try to restore it to factory settings... if nothing happens, you might have a prob in your keypad flex...
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
