Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
My Panasonic TH-50PX60U Plasma TV screen went to bright green.
I have a panasonic th-50px60u plasma tv, and the screen went bright green when I turned it on this morning. I have sound but no picture. I am on comcast cable and I have had this set for three years with no problems until now. Comcast id doing upgrades that requires me to have a Digitial Transport Adaptors on all my sets in order to continue to receive chanels hegher than 30. After installing these, my problems startes. Can any one help with this!!!-
Adjust brightness on panasonic th-50px60
The TV's Brightness setting only affects the intensity of the color white. The easiest way to see changes is to pause a movie or TV show that has clouds in the image. Then change your Brightness setting to your preferred video.
Mar 18, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Dec 12, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Try to open the back cover and remove the SD card cable from the connector.
Dec 28, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic th-50px60u
If the glass that you can feel on the front of the tv is cracked, then just replace the glass (called filter). The cost is about 150.00. If the pannel is cracked buy a new tv. It costs to much.
Nov 26, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
448 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
