Need a link or a piece of writting that i can copy to go into word then print out a repair manual for when my dyson goes faulty please could anyone help me
Hi there, it's Jack at Dyson.
Our online Support pages for DC04 contain all the information you might need to know to resolve issues with your vacuum in the event of a breakdown: http://www.dyson.co.uk/support/dc04/dc04-brush-control
Although it's an online guide, and is designed to be navigated quickly and easily via your web browser, the pages could also be printed out if you wanted a hard copy.
I hope this helps, but if you'd like any further information or advice, please give our freephone UK Helpline a call on 0800 298 0298.
SOURCE: Dyson
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
SOURCE: Dyson dc04 motor runs but has no suction.
I would make sure it is the motor first by isolating the sounds to just the motor. Take off the dirt cup, both filters, and belt, then run it and see if the sound is still there. If it is, you need a new motor. If it isn't, you need to look for a clog, or bad roller bearing.
To take the motor out first undo the wiring running down the backside of the unit inside of the switch housing. Then take the four screws out that hold the outer motor housing on, and the rest pops apart. Once you get inside, the gaskets make it a really tight fit, so you might have to hit the motor shaft with a rubber mallet to get it out and use penetrating oil on the bottom gasket to get the new motor to slide back in.
I guess there is no easy explanation. Let me know how it goes.
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
SOURCE: why does my dyson dc04
This post may be of assistance: http://www.fixya.com/support/t2842769-fix_new_power_cable_dyson_dc07
Hope it helps
SOURCE: How do I change the main cable to DC04 MAINS
Have a look at this link:
http://www.dysonmedic.com/DC04%20Folder/DC04%20Cable.html
