Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Getting F2 Error Code after self-cleaning
Hi I have a Jenn-Air WW30430P oven.
The display panel is showing a F2 error code after we tried a self-cleaning. The F2 code continually beeps, and the oven will not heat up anymore.
What do I do??
  • 4 more comments
  • yellowjess Nov 16, 2007
    I also just used the self cleaning mode on my oven and now I am getting F2 code. Who do I make it stop?
  • Anonymous Dec 02, 2007
    Have jenn Air and Getting F2 Error Code after self-cleaning
  • Anonymous Dec 21, 2007
    I have the same problem!
  • Rosest Feb 11, 2008
    F2 error code continues to display after self cleaning.  I cut the power for about 10 minutes, but that didn't help.  A solution would be appreciated.
  • Lynnlewk Apr 24, 2008
    Used self cleaning and now get constant beeping of F2
  • larsenm Apr 07, 2009
    F2 error code continues to display while cooking. I cut the power for about 10 minutes, but that didn't help. A solution would be appreciated.
4 Suggested Answers
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
here is a link to the diagram.
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 706 Answers
SOURCE: lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Posted on Feb 16, 2009
  • 5603 Answers
SOURCE: The control panel display light is completely dark
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Posted on Jan 31, 2010
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
We have replaced the relay board on a jenn-air ww30430p 2 different times now and still getting same error codes F5 and F4. One error code is for sensors and the other is indicating a short in the wiring...
there is a big difference between an open circuit and a dead short
you will still get a reading indicating a circuit even with a dead short which is your code
suggest that you get in a technician to find the code faults as it is costing you money guess replacing
Jan 01, 2018 | Jenn-Air WW30430P Stainless Steel Electric...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-air ove3n flashing a error FR
hi friend,
condition:second oven error sensed
resolution:1.check oven temperature sensor and hardness[or]
2.replace second board
hope this helps u
thank u for using fixya
please rate me....................
Sep 14, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
553 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
