Question about Dryers
I have a Kenmore 400 model 110.67422600, the belt fell off from around the drum. I do not see in the manual any directions to do so. Is there any manuals online that I can view or what steps do I need to put the belt back on around the drum.
    Sergeant:
    Champion:
  • 235 Answers
First, make sure the belt is not damaged. Secondly, belt goes around the drum first. then around the motor pulley. And last, around the tensioner from the farthest side of the pulley. Good luck!
Posted on Jun 30, 2009
The dryer belt broke. I bought what I thought was the replacement belt but it is too large to fit the drum and tensioner pulley. Upon inspecting the motor, the shaft has a grooved portion around which...
You did not provide the model of your kenmore dryer so i can't provide the correct part # HOWEVER
you can go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter your model number and get exploded views of your machine, part numbers and the ability to order them directly from Sears
Feb 05, 2011 | Kenmore Dryers
Tip
Kenmore Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Kenmore models starting with 110 or C110 with a removable back use this:
Style: Flat with ribs
Installation Tips: Ribs against drum
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Installation Tips: Ribs face toward drum
on Mar 06, 2010 | Dryers
The tension roller and bracket fell off how do you reattach Kenmore400 dryer
basically you will have to remove the drum, reattach the bracket, roller, start belt and reinsert drum
Jul 20, 2010 | Kenmore 400 6943 Dryer
Where is my belt on my kenmore dryer model #66822692 series 80
The belt goes around the drum 1b15519.jpgThe part number being 341241 on the common Kenmore dryer.
409d816.jpg110ef8a.jpg899f2ef.jpg19a8834.gifoil them rollers and idler. Old school training manual
MORE
Jun 29, 2010 | Kenmore Dryers
Looks like a belt underneath fell off.whats that for and how do you replace it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
If it's a direct drive washer, the belt is likely simply a sound deadening device (a rubber belt about 1/4" high and about 8" around ) that fits around the brake drum.
If that is it, and everything else is fine, you don't have a problem.
Mar 12, 2010 | Kenmore 22422 Top Load Washer
Kenmore 62084 electric dryer belt fell off i need directions on how to get it back on
Good day,
I'll include a link that shows you how, however, there is usually a cause for the belt doing that.
You should make a close inspection of the belt, as well as all the bearings. You can check the rear bearings, by lifting the drum out.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Jan 17, 2010 | Kenmore Dryers
Banging noise when the drum is spinning
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
You can get a parts manual from this website:
http://www.applianceaid.com/
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 13, 2009 | Kenmore Dryers
I need Directions how to replace the belt.
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......
May 04, 2009 | Dryers
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Dryers Logo
238 people viewed this question
Top Dryers Experts
