Question about Toshiba TP50H50 50" Rear Projection Television
Accidentally plugedd tv set into 220 outlet need service manual tp50h50
  • 767 Answers
The fuse should have caught most of
the spike . but the pulse that got threw
may have fryed the regulators and
output trans , have you plug it in to
120v yet?
Posted on Jun 30, 2009
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
Why does my t.v. automatically shut off after 15 seconds?
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 16, 2011 | Sylvania SRCD227 27 in. TV/DVD Combo
No color
Jan 15, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
No sound output need sound unit
Jan 14, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
How can i exit from service menu code,picture is blinking and there is no sound.Service menu is appearing when set is power on. set is 14''philips vardaan . please shortout my problem.
Jan 13, 2011 | Philips 20DV6942 20 in. TV/DVD Combo
How can i fix color broplem of the television?
Jan 12, 2011 | Aiwa VX-T1470 14 in. TV/VCR Combo
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Accidentally conected it to 220 volt outlet
Hi, damage should be limited to low voltage power supply, I would definitely have a tech take a look at it, video-tek
Jul 03, 2009 | Toshiba 50HDX82 50" Rear Projection...
TP50H50 Black Box on screen
you may have the set in text mode (part of the closed caption menu)
Feb 07, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
