Question about Bionaire Dehumidifiers
Seems to work fine but dosn't collect water
Surrand Air Dehumidyfier TWD-810B2
The motor seems fine, but it no longer collects water or helps the clothes dry. It is an Airforce model BQDD122FW. If it is the heater element, how much should it be to repair, roughly?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 20, 2011 | Dehumidifiers
It runs but does not take humidy out of the air. There is no water in the tub. The compressor seems very hot to the touch. I cleaned the filter. The fan motor is working fine. What do you think the problem...
heatman101
Aug 27, 2010 | Fedders Dehumidifiers
The fan on unit works fine but collects no water. It also gets quite hot on back.
Hello my name is Heath it will be my pleasure to assist you. The problem with the unit is it could have a plugged up coil or there is not enough moisture in the air to collect a noticeable amount of water. It may be collecting water but it could be boiling off before its collected in the drip pan.
Jun 13, 2010 | Danby DDR4007EE Dehumidifier
Dehumidifier does not remove water from the air.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 31, 2010 | Maytag M7DH45B2A Dehumidifier
The dehumidifier runs fine and the condensor seems to be running but it is not collecting any water. I have it set at 30% and the air is at 65%. What might be wrong?
heatman101
May 25, 2010 | LG LHD45EL Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
A challenge dehumidifier not collecting water
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 03, 2010 | Maytag M7DH65B2A Dehumidifier
Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Oct 07, 2009 | Haier 45-Pint Dehumidifier
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Jun 24, 2009 | LG DH30 GoldStar Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
