Question about Hayward Pool & Spa
Engine making humming noise and will not run
When the engine is turned on it makes a humming noise but does not pump any water. I was told this could be from a thermal overload but i am not sure if that is the case because it has not been very warm out at all.
  • 110 Answers
Impella could be stuck on pump...
Tap lightly - see if it free's up.
If you can remove pump - and have not got it conected to mains power - turn impella using knife or screwdriver.
Spray some WD40 around moving parts.
Most pumps will frez up at some point.
Posted on Jul 07, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Kenmore 600 series washer stoped in the fast spin cycle all it will do now is make a stuck humming noise
The humming can be the pump motor, running for a certain time, to make sure all water is out. It should stop in a few minutes. If not, it could be a glitch. If the error keeps coming back, please contact a repair engineer.
Aug 31, 2014 | Kenmore Washing Machines
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
Humming sound coming from engine told it was the alternator
This noise could be the alternator, water pump, power steering pump, idler pulley or tensioner pulley. Sometimes an automotive stethescope is used to isolate noises around the engine.
Dec 20, 2012 | 2002 Chevrolet TrailBlazer
Some time when i start my car the engine will make a humming sound. and some time when i am driving the engine will make the same noise.
Turn off the airconditioning to see if that helps. If it does, then it is likely the airconditioning compressor.
Remove the water pump drive belt. Feel the water pump for free play. If excessive, then replace the pump. You can try spinning it too to see if it's noisy.
WIth the drive belts off, start the car for a few seconds. Twenty seconds tops should do it. Not too long as it will overheat.
Is the noise still present. If not, then check all pump bearings, pulley bearings, tensioner bearings, water pump etc as the noise is one of those things.
Nov 12, 2012 | 1995 Lincoln Town Car
Intex sand filter motor will not run
Opening the little drain plug at the bottom should relieve the pressure and make it easier to turn the basket lid. Is there water to the top of the basket? I had to loosen the clear top of the basket to bleed the air out. If you open the drain where you backwash, will water flow out? It should. Mine flowed out even without the motor running if I remember correctly. If it does not, my guess would be some kind of obstruction.
Increase Engine Horsepower.
Jun 02, 2012 | INTEX Sand Filter Pump
I have a Starbucks Barista Espresso Sin 006 that I got used from someone. They hadn't used in it awhile and didn't have the manual. I'm told that before using I should Prime it. The instructions says...
Hi
Since the machine hadn't been used in a while you might have a stuck check valve in the pump. You say it hums. Does it rattle or just hum? If it hums something is stuck in the lines that is keeping the pump from moving water. If it rattles and makes a lot of noise its the pump check valve or it could be a plugged flow meter/ intake line.
Jan 16, 2011 | Starbucks Saeco Italia Digital Barista...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Pool & Spa Logo
545 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
