Question about One For All URC-4330 Remote Control
Cannot access menu
Programmed remote for Sears TV, want to have closed captions available, but cannot open menu
I tried every number code listed on the website for "Sears" and finally found one which gave me menu access. Some codes evidently work for some functions, but not for all.
Posted on Jun 30, 2009
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Oct 31, 2013 | Televison & Video
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
I have a philips flat tv Model # 42pf9630a/37, lost the remote and I can't program a remote to access the menu. The Closed caption is on and the screen format is not right.
I just checked and your specific remote is available on eBay for between $15 and $35. Just search the model number.
If you don't like eBay then consider a Logitech Harmony remote. They are easy to program and they will have all the functionality of your original remote including menu functions. I have two Logitech Harmony One remotes and there isn't a single thing I can't do that the stock remotes can do better. They are sold at Amazon, Tigerdirect, Walmart, Bestbuy, and just about any other electronics store.
Jul 26, 2012 | Philips 42PF9630A 42 in. Plasma Television
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
One For All URC-4330 Remote Control Logo
100 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
