Question about Nintendo NES Console
I have installed the 72 pin, but the graphic, seem to work but dont quite line up, it is like the graphic are squares and distorted
  • 36 Answers
Make sure the cartridge is clean, too. A shiny brand new 72 pin won't work well if the cartridge contacts are dirty.
Posted on Aug 02, 2009
    Problem Solver:
  • 5 Answers
The cartrage might not be inserted right or the 72 pin connector isnt lined up right so i would try installing it again.
Posted on Jul 02, 2009
NES Glitching after New 72 Pin
You may have to face the possibility that the NES internal graphics card is old and now irreparably damaged. Unless you can procure and install another one, then the console may just be on its last legs
Jul 19, 2010 | Nintendo NES Console
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
How do you get the hard drive out of a Toshiba Equium 7100D computer?
It's been a Long time since I have worked on one of these, so forgive me if my information is somewhat sketchy.
If memory serves the Left side of the case comes off. (Viewing the desktop computer from the front.)
There are clips underneath that need to be depressed, in order to remove this side cover.
From there with a flashlight, you should be able to view the other corresponding clips to depress, and remove the rest of the cover. Believe it lifts up so far, then slides forward.
At the Front Right side is the CD drive. There is a single screw you remove, and then the CD drive tilts up. From there you will see a single screw, that holds the harddrive in.
Once you are able to lift the harddrive up a bit, you wiggle the whitish colored plastic plug, side to side, as you pull out. This is a 4-pin Molex connector. It provides power from the power supply to the harddrive.
Sometimes this Molex connector can be QUITE tight, and hard to remove. DO NOT pull on the wires! If you use finesse, you can use a pair of pliers to wiggle it out. I advise using a Lot of finesse, as you can crush the plug. Sometimes it requires a bit of force!
The Molex plug looks like this,
http://en.wikipedia.org/wiki/File:Molex_female_connector.jpg
Then the 40-pin interface cable connector is removed. (Flat ribbon cable goes to this connector) Use a Lot of finesse here, as the tiny pins can be bent Quite easily!
Now the harddrive is in your hand, and you can examine it more closely.
The 4-pin Molex connector only goes in the harddrive, in one direction.
The top corners are tapered, and allow the plug to be installed only one way.
The 40-pin connector may be another story!
Looking at the connector itself, observe if there is a square lug on top. (Square plastic protrusion, emanating from the top edge of the rectangular plug)
This square lug lines up with a cutout in the back of the harddrive. It puts the 40-pin connector, in the proper position in the harddrive.
If this square lug is absent, don't fret when you go to re-install.
I will advise you the way to do it properly.
On one side of that flat ribbon cable you will see a faint Red line, or stripe. This Red line corresponds with Number 1 pin in the ribbon cable. Number 1 pin is on the side where the Red line is.
Viewing the back of your harddrive that you're going to install, (It is an IDE harddrive. Also referred to as EIDE, ATA, or PATA), note the pin locations.
All the way to the right are 4 pins. This is where the 4-pin Molex connector plugs into.
To the immediate Left are the Jumper pins.
To the Left of the Jumper pins are the 40, (39 actually), pins where the flat ribbon cable plugs into.
Number 1 pin goes towards the power connection.
The Red stripe on the flat ribbon cable, will be facing the 4-pin power connection on the harddrive.
If you have any further questions on this, please come back, and post them in an additional comment.
Oct 18, 2009 | Toshiba Equium 7100D PC Desktop
Squares appear when i play games
Try updating graphics card driver
if that does not fix, then try to restore it to previous date when it was working
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Display distorted
Install Proper Driver for VGA
Download and install from www.dell.co.in
Jun 24, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
How to solve no 100: seven squares
There are 28 PINS. Count each PIN starting from left to right on each line. (1 to 28 )
Square 1-- Join together PIN No's ( 1 -- 2 -- 6 -- 7 )
Square 2 -- Join " " " " ( 4 -- 12 -- 21 -- 27 )
Square 3 -- Join " " " " ( 5 -- 9 -- 11 -- 15 )
Square 4 -- Join " " " " (3 -- 10 -- 13 -- 19 )
Square 5 -- Join " " " " (8 -- 16 -- 23 -- 28 )
Square 6 -- Join " " " " (14 --18 - 20 -- 25 )
Square 7 -- Join " " " " (17 -- 22 - 24 - 26 )
Hope you can complete this Puzzle now ----------- GOOD LUCK
Apr 01, 2009 | Nintendo Professor Layton & the Curious...
Distorted picture and graphics
it means the resolution of the photos that you have downloaded is small . and when you zoom it , it get distorted .
so try downloading large resolution images .
minimum resolution should be 800 * 600 for good quality ..
Mar 15, 2009 | Computers & Internet
Vertical lines at BIOS splash screen
Is your power supply rated to hand the board and the graphics card and all the other hardware?
Did the issue star with the video card?
try removing the extras like the CD drive and any other PCI devices and just putting the graphics card in and whats needed to boot the computer.
Also, reseat the graphiocs card.
also try installing just the drivers for the video card without any of the over clock software.
Try resetting your BIOS by disconnecting the power cabel and removing the BIOS battery and waiting a minute, put back in and restart/
Feb 03, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Viewsonic VX912 Distorted screen
for meantime use the previous monitor suitable to your pc then download the files you need enabling the new monitor to work.
Oct 15, 2008 | ViewSonic VX910 19" LCD Monitor
WIDE SCREEN MONITOR
Better to reinstall windows(Operating System) and drivers.
Thanks
Mar 01, 2008 | HP Compaq Presario V2000 Notebook
Nintendo NES Console Logo
275 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
