Question about Dell 922 All-In-One InkJet Printer
Printer will not print
When I try to print I receive a message stating the print cover is open. I checked the cover and it is not open and there is nothing stopping it from closing. I can't turn my printer off without having to unplug it.
  • Anonymous Nov 27, 2007
    when I turn on my printer dell922 a message comes back saying cover open and the power will not turn off until I pulled the ac plug.The inkjet cartriages will not come into view when the cover is lifted. I have tried turning off the computer, then turning it on. Have opened the cover and reseated it to no avail
  • sharon m Jan 23, 2008
    I have the same problem. I tried the suggested solution of unplugging and plugging back in with cover open several times but it did not fix my problem. Message still says "cover open" and I am unable to use any other function of the printer. Any other suggestions?
  • 3 Answers
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Posted on Dec 29, 2007
    Guru:
  • 1,463 Answers
Have you been to dells web site
http://support.dell.com/support/index.aspx?c=us&l=en&s=gen&~ck=mn
riz.
Posted on Nov 19, 2007
How to print faxes from the lexmark x5630 which is stored in the memory
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Printer cover open
hi im josh in cebu phils. may i help you?
Friend if the printer states that the printer cover is open. it means that the cover of the printer is open or not locked. the cover above the cartridge is the one mentioned.
1. Be sure to lock or closed the printer cover before printing because if it is open it will not print because the software automatically detect the unclosed part of the printer.
2. check whether the hinges is safely attached it can be found in the printer cover side attached to the body of the printer.
3. try to see if there are some pieces of papers attached or stuck in the cover that's why it detects uncover.
4. clean the cover with soft cloth remove the dust and other dirt.
5. Reboot the pc if the solutions 1-4 is already performed and still warns the problem.
6. Lastly reinstall the printer software CD if the solutions1-5 is already performed and the problem stills occur.
Good luck friend hope i helped you.
Mar 10, 2009 | Lexmark X2250 All-In-One InkJet Printer
Printer is showing a system error of oxc19ac3ff ink system failure and will not print receive faxes or copy please advise
I had the same problem & found the solution of HP's website. It solved the problem.
HP Website & solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=1153494
Solution one: Reset the product
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Photosmart 335
Open the cover up where the cartrige are , the carriage will get to the center, then take the cartridge out close the cover.
Turn the printer off then on , put the cartridge back. try it
Mar 26, 2008 | HP Photosmart 335 InkJet Printer
Lexmark E238 Laser Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
Dell 922 All-In-One InkJet Printer Logo
535 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
