Question about Craftsman Saws
Looking to find repair parts for this table saw. I need a new arbor and gear mechanism to raise blade. any place to purchase these items?
  • rsallot Jun 30, 2009
    This is a generic answer for generic table saws.
    I have a 1938 8" saw model 10102141. I was hoping to find parts for old or antique table saws. I have been to the sears site and they don't recognize the number in their search engine. I am not sure if anyone carries parts for these "OLD" saws.
    Thanks for the time.
    President:
  • 1,996 Answers
Craftsman parts are available online from www.ManageMyHome.com, the official Sears support site.
Depending on the age of the saw, you may be able to locate them there...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 30, 2009
  • efs_perpends
    efs_perpends Jul 01, 2009
    An answer can only be as good as the question. Try this site. They may not have parts, but there's a forum where you can ask fellow owners, et.al., and it's a great resource for old machines, with some parts links.
The blade is hard to raise and lower
Check the threaded rods that turn to move the motor assembly up and down. These rods are sometimes oiled or greased and this just attracts saw dust and eventually binds up the system. Clean as best you can and the threads they turn in to raise the blade. Also check the tilt rods.
Another thing to check is the joints everything pivots on. Occasionally a small peice of wood can get in just the right (or wrong) place and the motor assembly won't move because it's blocking the pivot points.
Jan 06, 2012 | Ridgid Heavy Duty 10" Portable Table Saw...
Having problem get blade off table saw any hints
Unplug the saw, first and foremost.
Then see if your saw arbor has facets for a wrench behind the blade, and if so, try to find a slim wrench that fits there to hold the arbor while you attempt to loosen the arbor nut that holds the blad on. If that doesn't work, take a stick of wood, like a piece about 3/4" x 1 1/4" x 12-16" long, remove the throat plate from around the blade, wedge the stick between the blade teeth and the edge of the throat slot to hold the blade in place firmly, exerting levered force toward the center of the blade to hold it in place, and using the wrench, loosen the arbor nut. Make sure you are attempting to loosen in the correct direction. Depending which side of the blade the nut is on, some nuts are reverse threaded.
Good luck.
Jul 19, 2011 | Craftsman 10" Table Saw
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
--W/D--
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
How to change mitre saw blades
you need to remove the "throat" plate and raise the blade fully. UNPLUG SAW FIRST there are 2 wrenches on the side one for the hex nut and the other for the arbor, the threads are standard. let me know if you need more assistance
Aug 25, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I have a Sears 10 inch bench top table saw. Model 133221770. purchased in 1998. Lost the ''collar blade''. Sears stopped making the part, can I substitute or where can I find one?
If you can measure the arbor size, (the spindle the blade goes on), just buy any collar that will fit. The basic purpose of the collar is to spread out the force over a larger area of the blade from the arbor nut when it is tight.
Jun 08, 2010 | Craftsman Saws
How do I lock the spindle in order to change the blade?
As long as the threads on the arbor and the nut are in good shape, you don't really have to hold the arbor from turning, just the blade. Use a block of wood in front of the blade with the blade raised all of the way. Put the wood down in recess in the table in front of the blade and just pry against the blade. This works almost as well on the back of the blade when you tighten the nut. When you are tightening, the teeth are not pointing to your advantage, but you don't need to tighten the snot out of it.
Jan 25, 2010 | Craftsman 10" Table Saw
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Has become difficult to raise & lower blade
I have a similar saw and love it. I saturated the gear with silicon spray and worked it a bit. This seened to do the trick.
May 07, 2009 | Saws
12" craftsman table saw 0 to 45 deg adjustment gears striped
Sears has a site for parts and owner manuals at www.ManageMyHome.com.
It could be something is just loose and out of adjustment so that the teeth were able to slip on the gear. But I've never had a look at one of those to say for sure...oil always helps these things move easier...
Apr 19, 2009 | Saws
Saws Logo
70 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
