Question about Pentair Minimax NT Heater
Heater powers up and then makes a high pitched noise and click as it tries to ignite - will not ignite at this time
  • 83 Answers
I will need more information about the heter, is it gas or LP, do you see any error codes, lights, any information that you could give will help out! It could be the ignitor, blockage, low fuel supply, thermister, too many options!
Posted on Jul 01, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Fix High Pitch Noises In Cold Water Pipes?
Copy following link:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Do you have new water heater?
http://waterheatertimer.org/New-water-heater-making-noise.html
what have you tried so far? When did noise start? What other things do you notice? What changed?
Gene
mm
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2013 | Mountain Plumbing Water Heaters
Screeching noise
No you have a obstruction in the gas valve and this is not servicable.
Jul 01, 2013 | Heating & Cooling
Heater/air conditioning blower fan makes high pitch noise
Above the passenger's feet, 3 bolts to loosen and it comes right out...
Jun 05, 2013 | 1994 Mercury Capri
High Pitched noise coming from Williams Wall Heater
open it up and you'll see it while its running sounds like fan bearings or fan misalignment may need a new fan motor. if you replace the fan though make sure all power is off before disconnecting
Jan 24, 2010 | Williams 3003622 Ceramic Wall Mounted...
High pitch noise when water is turned on.
that's a faucet problem, nothing to do with the tank
either replace the faucet washer (The one that's noisy)
or get a diffeent style faucet
Aug 31, 2009 | Water Heaters
Intermittent non-starting caused by high pitched whirring when key turned in ignition
Hello;
The problem you are experiencing is one of two possiblilties. First, the bendix is weak in the starter. Best course of action is to replace the starter. When you pull the starter out, use a pry bar or screwdriver to rotate the flywheel an inspect the meshing teeth of the flywheel. If there is a section that has worn teeth then the flywheel needs to be replaced.
Thanks;
Rich
RPM Northwest
May 29, 2009 | 1987 Toyota Camry
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High Pitched whine when using line out with car power adapter
I was ready to mention the car's alternator but you say the noise is there if the ignition is on or off. What type voltage adapter are you using? It sounds as if it's the culprit. If it's an inverter I could understand the noise being generated. Have you tried earthing ALL the components involved? Earthing problems can cause some mighty weird things to happen.\ Are you sure nothing else in the car is switched on? eg. another radio or something with an inbuilt oscillator. Try running the power for the adapter straight from the battery and put a noise filter in line. Are you turning the engine off but leaving the ignition switched on? Doing this can cause a noise from the fuel pump. Oh and make sure the antenna is correctly earthed. Apart from that, I'm stumped BMW
Jul 17, 2006 | Tao XM2go Satellite Radio Receiver
Pentair Minimax NT Heater Logo
256 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
