Home | Danby | DMW773 800 Watts Microwave Oven | My microwave does not...
Danby DMW773 800 Watts Microwave Oven
Problem for Danby DMW773 800 Watts Microwave Oven
My microwave does not heat but there is power
By maryanne_gue on Jun 29, 2009
my microwave is not heating.i try to press power level 10 then start its just the same problem.
Solution #1
posted on Jul 01, 2009
Not Rated)
bestdarngood
Rank: Guru
Rating: 89%, 429 votes
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Was this helpful?
Yes
No
Popular Solutions for Danby DMW773 800 Watts
Questions and Unsolved Problems for Danby DMW773 800 Watts
Do you recommend Danby DMW773 800 Watts Microwave Oven?
Answer
Answer
i have tried everything to make it stop but the only thing that works is unplugging it which is a... (More)
Answer
We had a recent power failure and now my microwave beeps intermittently and sporadically no matter... (More)
Answer
Microwave model - DMW753W Danby designer company Problem - As soon as plug the power it's strat... (More)
Answer
What does Fault 222 indicate? From: cbcaldwell@ns.sympatico.ca
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DMW773 800 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
