Question about Roper MHE14XKB Microwave Oven
Microwave oven not working
I have a roper mhe14xkb-1 above the range microwave oven which is installed in a cabinet. i was heating up some frozen waffles (per the directions) and the packaging around the waffles caught on fire. i turned the unit off and opened the door and put out the fire. i cleaned up the smoke residue and found that none of the plastic liner was burned. the problem is that now nothing works on the microwave. the breaker is set and had never tripped. does this unit have some type of "one time" thermal fuse or limit that may be open? i am a long-time hvac mechanic, but have little experience with this type of appliance.
please help. i am trying to fix this for my parents, who are on a fixed income. thank for any useful responses. jeffreyd.
  • Roper Master
  • 9,098 Answers
That model number looks a bit off. I'd say it's one of these:
MHE14XMB1
MHE14XMD1
MHE14XMQ1
But for a part like this, any of the above should be the same.
There are two oven cavity thermostats in this model, which essentially act as flame sensors.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
microwave oven not working - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here. (Try searching without suffix if you get no hits).
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Roper / Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jun 30, 2009
All works except turn table and will not heat
Check the Main fuse inside the oven.And check the cause why it trip.
if it fused then check the transformer physically for sign of burnt.
I all above things okay.Then you need DMM to check the resistance of magnetron(oven has 5000 v in it even unpluging from main)(please dischage capacitor if you want to live more).
Thanks
Please rate my work
Sep 19, 2011 | Roper MHE14XKB Microwave Oven
Does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 13, 2011 | Roper MHE14XKB Microwave Oven
Microwave roper model# MHE14ZKBO worked fine, but now puts out no heat, although everything else works o,k,
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 06, 2011 | Roper MHE14XKB Microwave Oven
We have a roper microwave that hangs over the stove and everything works on it, exept it doesnt heat. The turn table spins and it lights up the clock and all the buttons work perfect. What would be the...
If you have a friend to help you lift down the unit, you can replace the magnatron which may cost about 100-150.
Take model# and go to: www.partselect.com and find your part there at a good price
Jul 31, 2010 | Roper MHE14XKB Microwave Oven
Can't get roper microwave oven to heat
heatman101
dhhdg
Apr 22, 2010 | Roper MHE14XKB Microwave Oven
Fan blows turntable does not spin microwave does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2009 | Roper MHE14XKB Microwave Oven
Not heating
heatman101
hkgf
Nov 29, 2009 | Roper MHE14XKB Microwave Oven
Roper above the range
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 07, 2008 | Roper MHE14XKB Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave does not heat
check the control panel and related circuit,and check the door lock switches ,..
Sep 27, 2007 | Roper MHE14XKB Microwave Oven
Roper MHE14XKB Microwave Oven Logo
406 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
