Question about HP Compaq Business d530 Ultra-Slim PC Desktop
D530 Small Form Factor
How the heck do I get the power supply out of this thing?
The only screw I see is on the front. Removing that seems to
loosen it a little?
HP documentation is no help.
Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • dwood520 Nov 08, 2007
    I was scouring HP's website trying to find the manual last night.
    It's not as easy as going to the support section and listing the available manuals.
    I will tackle this today - thanks again.
Here is a link that will show you how to do this. This one is actually useful unlike most sites out there.
Posted on Feb 23, 2009
  • 3 Answers
If its the ultraslim, there are no screws. You flip the little green lever inside toward front edge of power supply and then slide the supply toward the front of the case. Lift up when it is as forward as it will slide (as back end clears the case. You'll probably need to remove the hard disk so you'll have the room to slide it forward.
Posted on Jan 14, 2008
  • 1,601 Answers
From the manual:
1.Remove the computer access panel
2.Disconnect all power cables from the mass storage devices and from the system board.
3.Remove the four screws that connect the power supply to the chassis .
4.Slide the power supply toward the front of the computer, then lift it out of the computer
Here is the service manual:
Posted on Nov 08, 2007
What graphics card is compatable for hp d530
I'm not going to go through a list for you, but I can tell that you don't have many options. The HP Compaq Business Desktop D530 uses a small form factor which means you don't have the same space as normal desktop users inside of your machine for the vast majority of display adapters. You would need at least a medium form factor for that.
The other problem is that your power supply is only 185W and can't supply the the amount of power needed for most desktop class display adapters.
The machine you are using wasn't designed to ever be used for gaming, and it shows. You would need to get a bigger computer case and higher watt (around 400 to 600 watt) power supply to support most desktop display adapters.
Jun 26, 2012 | HP Compaq d530 CMT PC Desktop
Does my hp compaq d530 SFF support agp video card?
The HP Compaq Business Desktop d530 Series Small Form Factor supports 1 Low Profile 8x AGP Card.
Sep 19, 2011 | HP Compaq d530 SFF PC Desktop
My compac desktop will not power up. At first, it froze when it was running, so I turned it off. Next it powered up, but the icons on the desktop started shimmering and flickering, so I turned it off...
Fortunately for you, it is with fair certainty that the power supply has failed and despite the custom form factor, aren't that costly to replace. Once you have the supply, it will be a fairly simple DIY swap.
Another bit of luck is that they are not only cheap but readily available:
eBay listing page
If you are concerned by unfamiliar tasks, take a few digital photos of the wiring placement for the supply to which you can refer if you get confused.
Dec 05, 2010 | HP Compaq d530 SFF PC Desktop
I cant get access to my laptop hp530 its asking power on password what do i do? Have tried removing the cmos battery but to no avail
you need to consult the customer care support line for HP on the bypass password. sometimes they might have to replace your bios.
Aug 12, 2010 | HP Compaq Business d530 Small Form Factor...
Pc hp dc 5000 sff does not power on, a red light keeps blinking, no beeping, no noise. Replace with a new power supply. Does the same thing
sounds like you have your answer, your computer is hosed. unless you want to keep swapping parts to try to see if it's memory or cpu, I'd just get a new motherboard/cpu/ram combo (they've come a long way since you got that computer, I'll bet)
Oct 07, 2009 | HP Compaq Business d530 Small Form Factor...
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
Power supply
What you need to be concerned about with Power Supplies is the Wattage (The higher the better) and its "Form-Factor." A Form Factor is the general size and shape of the motherboard. The most commonly used Form Factor is ATX or Mini-ATX. I would reccomend figuring out what size your case is either ATX or Mini-ATX (Baby-ATX sometimes) and you should be able to decided whether the PS is too big. Too small isn't a problem as long as you can screw the unit in tight.
Jan 20, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Graphics card
If you wish to upgrade your graphics card to a better one you will need to go out and purchase one. A good company is ATI they will have good gaming graphic cards. If you are still unsure about the graphics cards, or if this is not your problem you can e-mail me personaly at
All the Best,
May 27, 2008 | HP Compaq Business d530 Small Form Factor...
New sound card for HP d530 small form factor..
You just have to look for a "low-profile" PCI card. Creative makes one, Audigy SE SB0570LPVP
Search that for a vendor, or low-profile for other manufacturers.
Jan 29, 2008 | HP Compaq Business d530 Small Form Factor...
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
384 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
