Question about Carrier 36KCARMS Air Conditioner
Continous blinking of the green light
When we turn on our aplit type a/c, it shuts off by itself with the continous green light blinking, we tried turing it on again but still in the same mode as if its off but its on without the air coming out
  • Judes Jun 12, 2012
    I had this problem and apparently the coil eventually acquires a leak and the unit can be soldered as a stop gap but the ultimate end result is to change the entire condenser unit.
    This is an update as its 2012, but I just had this exact problem and when the service guy came out he noted the wet looking spot on the condenser and told us the coils eventually corrode (a flaw with these units) and the gas escapes. He soldered the coils as a stop gap but I have to eventually change the condenser unit outside. At least the solder will buy me time to gather the amount to do this. Hope this helps.
    Scholar:
  • 70 Answers
Try shuting off breaker for a few minutes and try again. Wash out outside coil.
Posted on Jun 29, 2009
    Sniper:
  • 81 Answers
This indicates that the unit may need to be serviced due to problems with the unit.
Posted on Jul 16, 2009
The green light blinks on and off again
Are your batteries fully charged ? is the LCD screen on ? Does the camera stay on or shut itself off ?
Jan 26, 2013 | Fuji FinePix A345 Digital Camera
Blinking green light
I get a blinking green light in my freezer when a piece of ice gets stuck instead of dispensing into the ice bucket. First break the stuck ice off then there is a switch beside the green light that you turn off then back on. You should be go to go again until the next time. Mine does it alot and I have a friend with the same refrigator and the same continous "stuck" ice.
Jun 25, 2012 | GE GSH25JFT
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Green light working continously
It might be you change your cartridge to that and you did not insert it properly so that they blink. Try to check the cartridge if it can insert properly then restart your printer and try to print it again. If they are blinking again just press the reset button or turned off your printer then turned it on again and try to print.
May 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Carrier 36KCARMS Air Conditioner Logo
2,505 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
