Question about Sylvania 6313CE 13 in. TV/VCR Combo
My sylvania tv won't stay on
The VCR hasn't been working for a while and I decided to try a VHS. I put in the video and it was split and fuzzy on the screen. I ejected the tape and all of a sudden the TV shut off by itself. now the TV won't even stay on for more than 20 seconds. How can i fix this?
Shuttle83
  • 1139 Answers
SOURCE: TV shuts off by itself
I think that this might be a power supply problem. The VCR might be loading down the supply and causing the shut down. If you are going to try to fix this yourself I would shuuest you get a schematic and multimeter, and an oscilloscope, here is why, The schematic will tell you what voltages are normal, The multimeter will allow you to measure those voltages, the oscilloscope will allow you to test for ripple voltage which might be present riding on your dc voltage level. If you do not have access to this equipment or do not know how to use this type of equipment, I would suggest that you take the unit to a shop.
Posted on Oct 03, 2007
SOURCE: sylvania combo tv/vcr turns self off
Same exact problem with my Sylvania combo.
Posted on Dec 19, 2007
headstrong
  • 233 Answers
SOURCE: VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Posted on Jan 08, 2008
SOURCE: SRCD227 tv/vcr/dvd won't stay on
QUE CLAVE O TECLAS DEBO OPRIMIR PARA ENTRAR AL SETUD
Posted on Dec 15, 2009
mybradley7
  • 242 Answers
SOURCE: Sylvania TV-VCR combo eats tapes
clean all moving parts
Posted on Jul 17, 2010
I have a number of VHS-C tapes from my various video cameras in the early-to-mid 1990s that I'm transferring to DVD via my DVD/VCR combo device. But several of of these tapes that have the suffix...
VHS-C and S VHS-C are two different animals. Super VHS-C will have much better video resolution than standard VHS and uses better videotape. A standard VCR will not play the Super format. You need a S VHS VCR. You would need not only a S VHS VCR but also a S VHS-C adapter. Yes, Not even the adapter is the same as a standard VHS-C adapter cassette.
You can send out your few S VHS-C tapes to a video conversion service. That might be the least expensive way to get them on DVD. Otherwise you could look on E-Bay.com for either a compatible camcorder (S VHS-C) or the S VHS VCR and the S VHS-C adapter.
http://vhs-to-dvd.com is one video conversion service that should be able to get your tapes on DVD for you. You could also look locally for a video service that does conversions to DVD.
Feb 19, 2011 | Televison & Video
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR to TV setup needed
Doreen, it is a simple job. At the back of the VCR you will find two sockets mentioned Video Out and Audio Out. Put the yellow plug in Video Out of VCR and the other end of this cable will have another yellow plug, which you put in the Video IN (PUT) of the TV. Take the White plug of the cable and put it in AUDIO OUT of the VCR and put the other end in RED AUDIO IN(PUT) of the TV, (Older VCRs like yours did not have stereo sound capability, and so there is only ONE Audio OUT from the VCR. )
Now, put a tape in the VCR and hit PLAY. Switch onthe TV and select AV1 or AV2. You should be able to get Picture and sound.
Nov 26, 2008 | Televison & Video
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Recording a tv show on a emerson vhs recorded problem
Allow the VCR to perform the much needed channel set up process... after this procedure, you will be able to record error-free...
May 30, 2008 | Emerson EWV403 VHS VCR
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Sylvania 6313CE 13 in. TV/VCR Combo Logo
323 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
