Question about Mitsubishi WD-52531 Television
Same problem with Mits WD-52531
I replaced the lamp which had died. Now the TV turns one, the green light is displayed for a few seconds and it shuts down. Sometimes the red led comes on but not always. Every now and then it will work but mostly it doesn't come one. This set is only two years old.
  • billthom Jun 30, 2009
    I checked the access door and the lamp assembly. Everything is seated properly but I reset everything just in case. Hit the reset button and same results, the green led flashes for a bit, then glows green then the set shuts down.
  • 4,234 Answers
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Posted on Jun 29, 2009
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 73 inch. green light blinks for a few seconds then the status light stays on. can hear a clicking noise when the green light is blinking. Replaced the lamp and that does not fix anything.
Mits has had an excessive number of problems with color wheels in some of their optical engines. Provided you replaced the lamp with OEM parts I would suspect the color wheel is causing the noise as well as the shutdown issues.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Mitsubishi WD-73736 Television
Mitsubishi WD-52531 not working after replacing the buld.
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Feb 05, 2010 | Mitsubishi WD-52531 Television
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
My WD-52825 wont turn on and its not the lamp....
If you want to have it repaired email me at ima_rm2000@yahoo.com i have repaired over 200 of these sets. I have been a professional electronics technician for over 40 years. email me for details and pricing. beter prices then mits or pts
Nov 05, 2008 | Televison & Video
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52531 Television Logo
411 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
