My thermostat is set at 70. I check it with a thermometer. It is accurate, I go to my living room and check the temperature. It tells me it is 64 degrees. Can you please help me. I have had the furnace checked several times. The filter is clean and so is the furnace. Please help.
Thanks
Depending on where your living room is in comparison to your furnace it could be just that the fan doesn’t have enough force to get it there so what is happing is that all the other air is reaching other rooms before it. There are products that can help with this u can find them at larger hardware stores they r inline fans that go in the ductwork or there r a flat type of fan that mounts on the vent and plugs into a wall outlet that will pull the air to that room the latter would be much easier but it is your choice. Hope this helps.
