Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Frost Free Refriderator has ice crystals forming on ceiling of freezer
eagle338
  • 4889 Answers
SOURCE: freezer no frost
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Posted on Oct 15, 2007
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
woobie dog
  • 1273 Answers
SOURCE: Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Posted on Jul 10, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
Accidentally left the freezer door open, and ice crystals formed.
You can defrost by turning off the power and leaving the door open, but if it is a frost free model it should gradually rid itself of ice at normal temp settings. This may take several days.
Apr 19, 2015 | Refrigerators
Items in freezer are gathering significant front, when the freezer should be frost free
A frost free freezer typically relies on a "fan" to vent that area of moisture. So, if the fan/vent is not working properly, the moisture in the freezer stays and become frost. Frost can also form if / when the freezer door is not closing properly / completely ... allowing air / moisture to enter the fridge/freezer . Have those checked out first.
Mar 03, 2014 | Angelo Brothers Westinghouse (r) Savona ES...
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
Whirlpool ET19DKXFW01 water dripping and heavy frost
Hi this sounds like a blockage in the defrost drain. Follow this link to my tips and tricks which will give you instructions on clearing the blockage. If you have any other questions please feel free to comment. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Dec 10, 2009 | Refrigerators
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Water leaking from ceiling of frig, no ice forming.
pat,this is tom.if your box temps are fine.then you have a blocked defrost drain.[if temps bad ,will condensate in fresh food because warm temps]couple ways one is to shut box down eight hours other is to remove the back frezer panel and clean out all that ice and clear drain.you can use blow dry to melt ice[watch water and electricty do mix at all,be carefil]once ice gone use weed eater line with nott in one end to push threw and come out ouher end and cleanin His name,tom
Jan 02, 2009 | Freezers
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
