Question about Averatec 1000 Notebook
I just bought two 1 GB memory for my Averatec 1000, after installation it onlt recognizes 1 GB of Ram. How do I get it to operate with 2 GBs?
  • 1 more comment
  • spotecus Jun 29, 2009
    PNY 1 GB DDR PC2700
    Windows XP Pro
    PNY 1 GB DDR PC2700
    Optima Memory
    MN1024SD1-33-BB
    Compatible with:
    PC2700 (333MHz)
    PC2100 (266MHz)
    PC1600 (200MHz)
    .999 GB RAM
  • spotecus Jun 30, 2009
    Thanks for the quick and helpful response. One of the RAM is bad.
    Sometimes we forget to be logic and methodical in our solutions when things don't quite work out like we expect.
This laptop should recognise the 2 GB of member. Can I please have the full make and model of both memory modules you have purchased?
Also, let me know what operating system you are running.
Thanks.
Posted on Jun 29, 2009
  • Anonymous Jun 29, 2009
    Thanks. I'll really need the full model of the module. It should be on a label on the module itself or the packaging or invoice. I can then ensure it is fully compatible.
    Also, if you could try going to Start, right-click My Computer, Properties. Does it show only 1 GB there?
    Thanks.
  • Anonymous Jun 30, 2009
    It really should work. Can you try removing one module and leave only one in there, boot the laptop and see if the 1 GB is recognised.
    Then remove that module and place only the other module into the same slot and boot with that and see if 1 GB is recognised.
    If one module wasn't recognised but the other was in the same slot, it could be a bad module. If both are recognised in the same slot, it means both modules are working.
    In this case, do the same thing as above, this time in the other slot. If the other slot doesn't recognise the module, it could be a faulty slot.
    Let me know how it goes.
    Also, kindly provide the exact model of your laptop please. I know it's the 1000 series, but is there anything else more specific on the base label of the laptop?
    Thanks.
Will my motherboard(D945GCNL) support 4 GB RAM?
No. The maximum that your motherboard will support is 2 GBs of RAM. 1 GB on each slot. Refer to this link: http://www.crucial.com/store/listparts.aspx?model=D945GCNL
Apr 11, 2011 | Intel D945GCNL Motherboard
I want to add memory up to 4GB. I have 2 x 1 GBs modules. can I add 2 x 2 GB's and remove the 2 x1 GBs? Also willing to move to Windows 7 64bit in order to move above the 4GB limit. Could I then mix the...
The memory specification for your workstation is here:
http://www.crucial.com/store/listparts.aspx?model=Precision%20Workstation%20T3400
You can remove the 1GB modules and replace with 2*2GB modules to give 4GB and you are correct in that you will need to use a 64-bit operating system to fully utilise 4GB or more.
Hope this helps,
Please rate my answer,
Chris
Mar 09, 2011 | Dell Precision T3400 375W 32bit Computer...
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
My motherboard has four 1GB DDR modules installed, yet it is only recognizing 2 GB. How can i get it to use all 4 gbs?
Hello there,
Some Motherboards can only use two Ram modules, we would need the make and model of the Motherboard and the make and model of the Ram .
are the Ram models a kit of Two or did you buy all four at the same time in one Kit here are a few questions to get us going .
Jan 27, 2011 | Mach Speed (MSNV-939) Motherboard
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
RAM is installed, but lap top does not read it
The 6735s requires DDR2 SODIMM chips clocked at 800 MHz and they must be installed two at a time (so a 2 Gb chip won't work - you need 2 1 Gb chips. Installing 2 + 1 Gbs will give you 2 Gbs only, (1+1), that is if the PC even boots at all; and so on).
Also, not all operative systems will read the full amount of RAM installed.
Oct 24, 2009 | HP Compaq 6735s Notebook
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | IBM PC 350 PC Desktop
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
Averatec 1000 Notebook Logo
41 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
