Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher/ paykel dishwasher says F3
My fisher and paykel drawer dishwasher says F3 and makes a grinding noise when it is runing.
  • 56 Answers
F3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Posted on Jun 30, 2009
  • 77 Answers
F3 means your dishwasher water is too hot. Go to the link below and it will show you how to determine what is causing the error.
http://www.appliancerepairlesson.com/category/dishwasher-common-issues-repair/
Good luck
Posted on Mar 05, 2011
F3 code and beeping noise
Not sure which model number dishwasher you have. But usually F3 error means a water temperature related fault. The water temperature is too high. Hopefully you are not using the hot water supply of your house. If so then ensure it is less than 80 deg C. If using normal mains supply (cold water) then it is likely the temperature sensor in dishwasher has failed. Not an easy job to fix as it is integrated into the water heater element at the base of the drawer for the DD603 drawer type dishwasher.
Mar 19, 2013 | Fisher and Paykel Dishwashers
I have F3 flashing on the dishwasher and it comes on by itself.
The heater unit is faulty. This is located at the base of the drawer and can be replaced by taking the drawer out.
The heater unit is available from FP in USA.
Please rate this solution to help fixya serve you better in future.
Aug 26, 2010 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykel Model DD603 Top drawer makes grinding noise while running.
Most likely the rotor is either damaged or there is some debris sitting in the rotor cavity.
Follow the instructions in the user guide to lift the filter plate. Then twist the collar that holds the rotor to free it up. Lift the rotor out carefully and check for debris in the rotor cavity.
Also see if there is any debris in the drain sump next to the rotor cavity. Take a thin rigid wire and clear the channel between the rotor cavity and the drain sump.
If rotor looks damaged you will have to replace it. Costs about $50.
Let me know how you go with this.
Aug 24, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a Fisher/Paykel dual drawer dishwasher and the top drawer now makes a loud grinding noise - appears to be coming from the front of the unit. Any thoughts? Any home-based solutions?
Remove dish rack, spray arm, remove filters, remove the rotor (under the spray arm) Check if the rotor itself is making any sound or not rotating freely when you turn the impeller on the top. Replace if needed, otherwise - carefully check for debris.
Nov 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
1,213 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
