Question about LG GC-051SS Compact Refrigerator
Mini fridge motor sounds like it is rattling. Noise just startted today.
  • 210 Answers
SOURCE: servis frost free fridge /freezer
not sure if it happens with this brand but I know others have a problem with ice build up that can interfere with the fan. If you can remove the back panel in the freezer section and take a look. If not try defrosting it for a couple of hours to see if it makes a difference.
Sgt 48
Posted on Jun 07, 2008
whytfang
  • 170 Answers
SOURCE: Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the Ice...it would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Posted on Mar 27, 2009
TheMazz
  • 78 Answers
SOURCE: Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Posted on Oct 28, 2009
SOURCE: ge profile psc23pswa rattling noise
I have the same problem. For me though, it's not the fan (I cchecked it as suggested). It appears to be the ice maker. The noise stops when the freezer door is open. The ice cubes are also not great (hollow). I think we had this problem before and it was a problem with the water line being frozen. Any suggestions?
Posted on Jun 10, 2010
AndreaBl
  • 218 Answers
SOURCE: My fridge is really quite and today i came home
if there is no problem in the functioning of this fridge then the noise isn't a problem. but still i would advise you to have this fridge checked out by your local repairman.
Posted on Jun 11, 2010
Rattling noise in engine
Pull the valve cover off to check for rocker arm. Could be exhaust leak if more of a popping sound than a rattle.
Sep 30, 2013 | Hyundai Sonata Cars & Trucks
Motor rattle on start up
I've never heard a Capacitor make a noise, but there's a lot of things I haven't heard, I have however, heard the start up windows make a noise when they start. One type pulls the start up relay in for the start up windings and can cause a noise sometimes. I wouldn't get in a big hurry to buy a new Refrigerator. Most of the time they do that for years and still work. Just guessing that that is the problem, have to hear it to know for sure.
Gillight.
Jun 22, 2012 | Frigidaire FRS23R4A Side by Side...
My fridge is really quite and today i came home and it sounds like a motor is humming or grinding!! when i open the fridge doors the noise goes away?
Jun 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Loud rattle noise when compressor cycles on
if this noise is coming from the compressor, it will eventually fail. If you just purchased it, i would ask for a replacement fridg and let the manufacturer deal with the repairs that it needs
Jan 07, 2010 | Refrigerators
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Fridge makes an odd rattling or woodpecker like sound intermittently. What could this be? Thanks.
If you have an icemaker, that would be the sound of either the mechanism emptying the cubes or the water valve shutting off. If the water valve is going bad, or the switch that shuts off the water valve is going bad, the water valve may 'chatter'. If this is the case, try shutting off the icemaker, or even the water supply to the unit to see if it stops.
If you don't have an icemaker, then the circulation fan may be rattling a bit or has something in it, like a bit of paper. Circulation fans are typically behind a panel in the freezer sectionon most models.
Some units rattle the metal cooling pipes a bit when the compressor motor starts up. This is a more metallic clanging sound.
If it's a very sharp repeated clicking noise, that may be the sound of the motor-start capacitor going bad.
Oct 07, 2009 | Hotpoint Refrigerators
Mar 26, 2009 | Refrigerators
LG GC-051SS Compact Refrigerator Logo
1,330 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
