Question about Maytag NMPEB08F2A Air Conditioner
After it runs for awhile it gets loud. Am I supposed to empty something, or recharge it after awhile? It's been used very little, but there is a loud fan noise when it switches from cool to fan only.It seems to cool well, but wakes us up after 2 hours or so. Skip
  • 294 Answers
Hii Skip Sounds like the compressor is going bad. Noise from the compressor usually means the compressor is on its way out. But noise can also be caused by cross-contaminated refrigerant (operating pressure too high), air in the system or the wrong type of compressor lubricant. Noise can also be caused by hoses or other parts rattling against other components in the engine compartment. Check the routing of the hoses, support brackets, etc., to pinpoint the noise.It happens. Call Sears back & get the manager. Scream loud!!!! Insist they fix it now or refund your money. (as u had used it recently...so warranty period is there i guess) That will get their attention.
skip hope u knw there r several rule n regulations reagarding the sound pollutions..i dnt knw about place.. so before your neighbour goes and complain about please fix it. i have 11 years experiance inthe field.. so i knw that the setting of the house(where u fix the ac) and the loose fittings can also add on to the sound.. so i recomend u to find a professionals in ur locality and get it fixed asap.
- i guess this old man deserve a drink.. wat do u say??
Posted on Jun 29, 2009
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
How to recharge ac
You can find what you need at the parts store. Get a r-134a refrigerant recharge kit. probably run you around $50 has refrigerant and oil plus what you need to install it into your system. It is real easy to do once you have the kit. If the system is empty because of a leak you will need to have that fixed or you will eventually run out again. Re-charging the system might work for awhile if your leak is small though. 1 thing, DONT take it to the dealer they will ask for your 1st born to fix it : ). Hope I could help you. Good luck.
Jun 26, 2012 | 1997 Cadillac Catera
There are alot of them... right now most importantly.. I was wondering how to disable the alarm.. as when I try and start the engine the horn blows the fourways go on... I just get out and unhook the...
Alarm is easy. Open trunk & leave open while you put one key in the ignition & one in the door & the buttons will then be able to turn off the alarm.
Jan 26, 2011 | 1994 Volkswagen Passat
2 yr old Whirlpool duet washer,suds and now f35 codes. Also when put on cold water i can only get hot water ?
the only reason you would get hot water on the cold setting is if the water lines have been crossed.you can usually clear the cosde by running nothing but clean water through the wash cycle and then use a little less soap.on the next was cycle.unplug the unit for a little bit then wait awhile and run the washer empty.
Nov 17, 2010 | Whirlpool Washing Machines
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
The washing machine makes loud banging noises when its running.
Either the machine is not balancing correctly or something mechanical has broken. If it works fine when empty then it is a balancing issue. If it does this even when empty then something has broken that supports the tub.
Jan 07, 2009 | Washing Machines
Shu43c Drain pump is very loud! This's supposed to be a quiet one
Drain pumps are relativley cheaply manufactured with basic technology, we can not even determine which way they spin, if something got into the pump it could be creating the noise, otherwise it could be the pump itself which will detereate over time, also if these run dry they seam to make more noise.
Nov 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Battery goes dead every few weeks..I recharge it and it will stay charged for a few weeks or months. Then goes dead again.
I just recently had the same issue.  Have someone check all the fuses and see what is drawing the power down.   Do you have electrical seats?  OnStar? Also have someone check your ingnition to see if it is fully turning off.  Trailblazers are supposed to have the 'run down protection' but something that drains your battery little by little could be the problem.  It seems that trailblazers need a lot of juice just to get started...
Jul 30, 2008 | 2008 Chevrolet Trailblazer
Dirty Tank Smells
You might try vineagar, if that doesn't work, put in some comet or some other scouring power, then fill w/hot water and let soak for awhile.
Feb 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Maytag NMPEB08F2A Air Conditioner Logo
160 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
