Question about Gateway EV 910 19" CRT Monitor
Monitor goes dark, need info
Sometimes it works fine then other times it just fades to black and will stay that way for an unknown period of time. Heat is not a problem as I keep my computer area very cool. (69-72F). Does this sound like a fly-back problem? Picture is fine otherwise, color and focus are fine it just goes dark now and then. I really want to get this fixed, I hate flat panels! If anyone can give me an idea of roughly what it will cost to fix, and do I take it to a TV repair shop or a computer tech?
Any advice would be appreciated..
  • Cee64E
    Cee64E Jun 30, 2009
    Thanx for the answers, folks. I've checked the cable and video card connections.Both are good, I'm using them now on my old 13" monitor. No problems.
    I'm trying to avoid getting a flat panel for several reasons. One is durability vs cost. Flat panels just don't last before they start losing pixels (dead transistors) or the backlight goes dead, usually within 5 years. CRTs can last 20 or more. Another problem with flat panels is resolution. Yes they have wonderful, high resolution panels on the market, but outside the panel's NATIVE resolution they can look like pure ****, CRTs have no native resolution and support the wide variety that I use daily very well. Speed is another factor. Really fast panels (under 5ms) are very expensive and I'm on a budget. I really hate ghosting when playing games or watching movies. My CRT is every bit as fast as my Nvidia Geforce card if not a little faster. CRTs are just better
  • 410 Answers
You won't be able to see it without taking the back off, but your CRT (picture tube) filament is going out. You could try to wriggle the CRT Tube Socket back on a little tighter then watch it for a while again. The PC Board should also be checked for bad solder connections in the 'hotter' areas. You should however be more open to the flat panels as the give great results and use less power. Let me know if this helps you.
Posted on Jun 29, 2009
    President:
  • 3,278 Answers
I was figuring that your VGA cable may be faulty. But, when you said "fade to black", now I'm not sure. Move the cable to see if the display changes and (I'm sure you have done this !) check to be certain that the cable is tightly connected to the PC port. There is a slight chance that your VGA port on your PC is faulty. Before you repair/replace anything, be certain that your monitor is the problem by testing with someone else's VGA (not USB) monitor.
Quite honestly, I have not had a monitor repaired - usually dispose of them (safely). Check with local agencies (incl.Goodwill) who repair PCs to see if they repair monitors, including replacement VGA cables. Good luck
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
The screen occasionally darkens significantly,
Have you tried using a different VGA cable? Or replacing the cable with a new one?
Dec 07, 2012 | ViewSonic Va2431wm LCD Monitor
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Gateway EV 910 19" CRT Monitor Logo
343 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
