Question about Thermos Stainless Steel Gas Grill
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
Grill itself wouldn't light. Looked under BBQ and I saw a wire hanging down with what looked like a white probe on the end of it. I could see 2 very tiny copper wires on very tip of this probe and a ring around it was rusty. I cannot get it to re-attach where it looks like it came from. I believe it is the ignitor switch, but am not sure. Must I replace my ignitor, and if so, are there and videos/web help I can get to safely replace this by myself? My Grill is a Thermos Select Char-Broil Outdoor Gas Grill Model #: 461620307 Serial #: G304020701 000479
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 35 Answers
The switch is a button on a black box that holds a battery. The igniter is connected to the switch with a wire. If the wire is broken, you need to replace the whole igniter. The igniter (with wire) and the switch are both available for a few dollars pretty much anywhere that sells gas grills.
Posted on Apr 29, 2017
    New Friend:
  • 42 Answers
If that white is ceramic, I think it is the actual ignitor, not the switch.
5 Suggested Answers
SOURCE: thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
  • 13 Answers
SOURCE: I was given a used Thermos gas grill and don't
you need a regulator and i sell them
Posted on Jun 27, 2010
SOURCE: i have a thermos grill 2 go model # 4656110 and im
Cadial, I would be interested in two plates if you still have any left. I have two of these grills and I love them, I've just worn the plates out.
Posted on Jul 03, 2010
6ylucy
  • 742 Answers
SOURCE: looking for a parts manual for a Thermos Gas Grill
ask here, they have it available.
Posted on Dec 25, 2011
We have permasteel gas BBQ grill. grill can be lighted up, but gradually died off. It seems that no enough gas pressure and flows. The regulator gets iceing and cold.
too much gas passing from reg causing freezing of gas reg or line or check for gas leak on reg , reg could be stuck open again too much gas pasing .
Jul 04, 2012 | Thermos Stainless Steel Gas Grill
Not enough flame and when i change the settings
it sounds like the reg off the gas bottle or blocked burner
May 15, 2010 | Thermos Grill2Go Gas Grill 4656110
Need a catcher for the fat off of the bbq grill
Go on line to Thermos grills and you should be able to order one there.
Apr 12, 2010 | Thermos Grill2Go Gas Grill 4656110
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
BBQ gas leaking from regulator vent
tou will have to cut off the hose at the crimp point a drimel wors real well then buy a new regulator and hose and automotive hose clamps 3/16 is best
Aug 02, 2009 | Thermos Stainless Steel Gas Grill
Replace ignitor on Thermos BBQ
You have to remove the front panel but It's not too hard. Remove the left and right side trays, about 4-5 screws each. Front panel will then come off readily. Detach the electrode wires from ignitor box first. Wear old clothes and gloves.
Dec 28, 2008 | Thermos Stainless Steel Gas Grill
Thermos Stainless Steel Gas Grill Logo
214 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
