Question about KitchenAid KERC607 Electric Kitchen Range
Kitchen aid electric stove does not go on
Elements on the stove are not heating
  • 56 Answers
Check the door lock switches on the door lock they get bent out of sdhape real easy
Posted on Jun 30, 2009
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Large Heating Element no longer heats
Is it the eye itself or the receptacle? solution: yank out the questionable eye and put another from the stove in that one. swap em around and determine if the eye is bad or the receptacle. The receptacle are around 10 bucks.
9f0ea2e.jpgpart number 330031
Mar 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KERC607 Electric Kitchen Range Logo
452 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
