Question about Braun Health & Beauty
How do I disassemble my Braun 5561 to replace the Battery without destroying anything? Thank you for your Reply. F. Weber
I found the following fantastic We-Site who has Scematic's for for all the Braun Shavers as well as many other Products. at ""NO Charge"".
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Braun+Espresso+Master+Plus
Posted on Jun 30, 2009
  • bvkoski
    bvkoski Apr 29, 2012
    I experimented with that link and the shavers are separated into 3 downloads. I suggest pasting one at a time into google (including the quotes) "Braun Shaver.part1.rar" "Braun Shaver.part2.rar" "Braun Shaver.part2.rar" and when you click on the google-searched finds that have those exact phrases in their site, click on the google link and the download starts immediately each time for each link. Then combine the .rar files, and you'll have a large collection of pdfs for the Braun shavers line, with exploded views.
How to replace battery in braun 5720
Braun Select Models Electric Shaver Disassembly Tutorial
1. Remove two screws on the bottom, where the power plugs in. Need to remove two ribber plugs first.
2. Pull from shaver head and remove shaver "guts" from case. (It will be hard to remove as it is encased in rubber to make it waterproof, but keep wiggling and tugging)
3. Remove old batteries and replace with new ones.
4. Re-assembly is reverse
Nov 08, 2013 | Braun 360° Complete 8985 Electric Shaver
How do you replace a battery on a Braun 7680 Shaver?
I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
Apr 19, 2011 | Braun Activator 8595 Electric Shaver
Need to replace the battery on a Braun 7526 shaver?
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll don the page for installation tip and video showing how to disassemble the shaver
Feb 28, 2011 | Braun Syncro 7526 Electric Shaver
How to change batteries on the 5416 braun shaver
You can do it yourself if equipped. First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
If this is not something you can do yourself, shaveroutlet.com can do it for you. See info and ordering at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Feb 19, 2011 | Braun Flex Integral 5416 Electric Shaver
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
Feb 03, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
How to disassemble the main body of a Braun Silk.epil super soft plus
Take it into a Braun service centre for best results. Or you can follow this video. You will see there are hidden tabs that lock the body together.
How to replace broken battery in Braun Silk epil 7
Aug 21, 2010 | Braun Silk-epil 3370 Epilator
Health & Beauty Logo
691 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
