Question about Irons
Norelco Steam Iron the water leaks out
Norelco easy steam iron 503 was working perfect for the last 6 years until I push the self cleaning button that it has, and now starts to steam but water comes out and it leaks. I don't know if the self clean button is stock or what could be the problem. Don't have the manual.
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
  • 8 Answers
SOURCE: gunk coming out of iron
Posted on Mar 30, 2009
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Gunk coming out of iron
Mar 29, 2009 | Irons
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
Please remember to rate this solution.
Feb 19, 2009 | Rowenta Professional DX8900 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Irons Logo
560 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
