Question about Gaggia Carezza Espresso Machine
Doesn't produce steam for more than 1 minute.
My Gaggia Carezza Silver Espresso maker has a problem with the steam pressure and steam wand. If you turn on the steam setting and the knob to full, it only produces steam for a bout 45 seconds to 1 minute and then slowly stops producing steam. I have tried descaling it with a descaling product and nothing has worked. I don't know if it would be worth it to try to fix it or just to buy a new one.
    President:
  • 1,618 Answers
You should not have your steam wand on for more than a minute.
Posted on Jun 30, 2009
2 Suggested Answers
  • 1089 Answers
SOURCE: Doesn't produce steam out of the steam wand for more than 1 min.
Hi.
That sounds like you have a bad steam thermostat. You can replace that your self. Its the thermostat on the top of the boiler.
The other one is on the side.
Posted on Jun 29, 2009
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia TS Espresso Machine although my machine seams to work OK, It does not seam to produce much steam any help would great
Their is a grait posibility that the steam want is blocked from dry milk that is why you have weaker steam out. So you can first try to boil only water for some minutes and then leave the steam want in for more than 30 minutes. Then try the steam again and posibly the dry milk will be spit out. You can even boil the water with some cooking soda in it which can help more.
One more think that can help to clean the steam wand is to use a thin flexible steel wire in the steam wand so it can clean it more.
This is the most posible solutions you can try.
Good Luck
Mar 22, 2010 | Gaggia TS Espresso Machine
Hi.
Jun 29, 2009 | Gaggia Titanium Espresso Machine
No steam
Is the coffee hot or cold?
If hot then the steam wand is clogged, try inserting a paperclip in the hole(Remove the parnello black plastic covering silver steam wand) at the end of the nozzle.
If cold then the element is not heating, if you remove the top panel on the machine there is a thermostat on the boiler. That might be damaged, some of them are resettable (it will have a red or brown pin in the middle) if it is a resettable one then push in the pin, if not then it will have to be replaced.
May 17, 2009 | Gaggia Classic Espresso Machine
Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Apr 03, 2009 | Gaggia Carezza Espresso Machine
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
Steam wand works, but no water for espresso
I have found that I have to remove the group valve assembly about once every 1 or 2 months to clean out the .030" to .040" opening in the valve body. The manual gives instructions on how to do this. It becomes clogged with a thick paste like substance.
Jan 24, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine Logo
285 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
