Ricoh Aficio 1013F Copier
Problem for Ricoh Aficio 1013F Copier
Message says to add toner after I replace toner
By ginny520 on Jun 29, 2009
I followed the instructions to replace the toner and after I replaced the toner the message continues to read to replace the toner
Best Solution
posted on Sep 02, 2009
Very Helpful)
rrrdddrrrddd
Rank: Wiz
Rating: 90%, 12 votes
1. Open front door and pull out toner hopper.
2. Remove toner and make sure it still hase the clear cap on the top fully inserted in the bottle. If cap is missing and you can see the toner in bottle, it's a lost cause get a new toner bottle.
3. Lay toner bottle in hopper and push toner hopper in the machine while keeping the green latch up all the way through the pushing motion. This is critical to ensure the cap will come off. Once toner hopper is pushed all the way in, push the green lever down. Again it is mportant to mention that the gree lever must be up till the toner hopper is ushed in all the way. Then and only then the green lever may be pushed down.
4. Allow machine to load toner.
5. If it still says add toner, open and close front door. Again allow machine to load toner. You may have to do this up to five times (open and close front door) to replenish the deleoper unit with toner.
This problem is common with these machines if you do several copies of a dark original or print. The developer gets depleted of toner, it just cant keep up and then the machine says add toner.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 11, 2009
Very Helpful)
sandmanmac
Rank: Wiz  Ricoh Expert
Rating: 84%, 785 votes
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
Was this helpful?
Yes
No
Solution #3
posted on Jul 01, 2009
Very Helpful)
savindude
Rank: Wiz
Rating: 84%, 80 votes
Alot of times when the PCU has reached it's life, it will continually say add toner. You might be able to do a bandaid repair by good cleaning, but I think the answer is to replace the pcu. Another idea, if you cheat the front door with folded paper or whatever, you should be able to watch the toner bottle. Is it turning? The toner motors can go bad where they don't come on therefore not adding any toner. Good luck. Please rate this. Thanks.
Was this helpful?
Yes
No
Solution #4
posted on Oct 23, 2009
Not Rated)
ingramd2
Rank: Apprentice
Rating: 0%, 0 votes
I have a Tally Genecom 8124 Printer and it says add toner M, So i have refilled it and it still says add toner M.
I only refill because Tally Genecom has gone bust so you cant get the toners anymore.
If any one can help please..?
Thank you
Dave
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1013F Copier
Questions and Unsolved Problems for Ricoh Aficio 1013F Copier
Do you recommend Ricoh Aficio 1013F Copier?
Answer
Answer
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this... (More)
Answer
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black... (More)
Answer
canon ir 1630 copier system erroe E245
Answer
service manual for xerox document center 440, where download free.
Answer
please what does the following codes means on konical 1212
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1013F Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
