My fridge seems to lean to the left rear side. How can I level it properly? Are the rear wheels adjustable? Can the front ones adjust?
SOURCE: samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
SOURCE: Kelvinator 360 Fridge Wheel Adjustment
If you have the manual.... check under leveling your appliance.
I don't know Kelvinator but most have screws/bolts that can be turned behind the air vent cover at the bottom front of the fridge that will raise or lower the fridge. Sorry I couldn't be of more help.
SOURCE: wheel adjustment on a ge fridge
if you take the front kick plate off by pulling on it. once the front kick plate at the bottom of refrig. is off bend down and you will see 1 bolt head that looks bigger than the rest of them. 1 on each side of the refrig. now if you need to lower the refrig turn to the left. to raise turn to the right. this do it for you. thanks eddy
SOURCE: one door lower than other, how to adjust door
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
SOURCE: leveling refrigerator
In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level)
Never less than in order to allow door to shut own their own, but there is nothing wrong with having a perfect level refrig if everyone closes the doors properly which they won't. A refrigerator requires to be reasonable leveled to avoid compressor fatigue. In a Motorhome people can't always find level ground, so it quite frequent that their refrigerator burns up when running. From that experience I'd say I would level any fridge which is over 1/2 inch off.
