Question about Haier ESA306 Air Conditioner
Cold air not coming out. I JUST bought this the other day and it worked the first day just fine but now it will work fine for about 10 minutes and then the cold air will stop coming out. Air will continue to come out but not cold air. It is summer in New York so help please. PLEASE. Thanks in advance. This is a Haier ESA306 window unit.
  • mcamacho1979 Jun 29, 2009
    i should have mentioned this before, my apologies, but i had another a/c unit last summer here and it had the same exact problem. i thought it was broken just like i thought this one was broken but do you think it could have been a voltage problem with the last one too?
    thanks so much for your help.
    this really sounds like it could be whats wrong and now i feel like an idiot for buying a brand new a/c unit. i dont really know how to check if the running wire is too short or long but i think im gonna ask our landlord to check it out. thank you so much for this!
    Scholar:
  • 70 Answers
Need to return this one where you got it. Sounds like compreesor or control problem. Do check outlet voltage to make sure it is not a low voltage problem first. Voltage should not drop below 10% of name plate voltage required. Voltage should be checked with unit running and cooling to see true voltage.
Posted on Jun 29, 2009
  • Kendall Clendenen
    Kendall Clendenen Jun 29, 2009
    Yes ! If it is a long run of wire or too small it will cause low voltage and over heat compressor or prevent it from starting !
  • Kendall Clendenen
    Kendall Clendenen Jun 30, 2009
    Hope that this helped. If it is plugged into regular outlet and one it still open it can be tested there. Apt buildindings sometimes have old wiring and long runs. Some times they end up with breaker or fuse bigger than wire is rated to carry. Please rate me as you see fit. Thanks!
    President:
  • 2,976 Answers
If you're using an extension cord, make sure it is at a minumum 10 gauge wire. Anything smaller will create a voltage drop that will create issues. If you are in the New York City area, you probably have voltage issues to begin with.
Posted on Jun 30, 2009
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
2004 mercury mountaineer air conditioner will not hold a charge
sadly freon leaks are hard to find and fixes are quite costly take it to a specialty garage that does air conditioning .
May 01, 2016 | 2004 Mercury Mountaineer
Hi i bought 2002 nissan sentra ..previous owner replaced head gasket ,water pump.thermostat ...car was running good for a week then sudeny no hot air inside(blows but cold) and 10 minutes later...
Thermostat is the wrong temperature range for the vehicle or it is installed backwards. It is opening too soon and not allowing the vehicle engine to come up to operating temperature soon enough. Have system checked, replace thermostat with correct temperature for vehicle
Feb 12, 2015 | Nissan Cars & Trucks
2003 Saturn Ion won't start in the cold weather
First of all your service light came on so give it a service then have the service light reset then check the thermastac, water levels and the choke is working properly and all the elecric working parts are good
Jul 05, 2017 | 2003 Saturn ION
Turbo air not blowing cold air
10 minutes?? So he added the gas and jumped in his truck and left?? WHAT COULD REALLY HAVE HAPPENED?
Feb 23, 2018 | Turboair TAS-24H Split System Air...
1987 thunderbird won't fire
ok dude i have had the same problem i have a 3.8 v6 i am not sure what u have but fine the negtive battery cable and there should be a little black wire follow it to a fuse type connector make sure it os on there tight it does some twisty type thing it is a kill/ground switch it is there so the car wont catch on fire and stuff like that next check the starter and ignition module try those few things and get back at me
tedlaning@yahoo.com hope it works
Oct 17, 2008 | 1987 Ford Thunderbird
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Haier ESA306 Air Conditioner Logo
279 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
