Question about Magellan Maestro 3225 Car GPS Receiver
Same Problem here
I get the same USB connected message when I connect either the car or the house charger into my Maestro 3225. They both still charge the battery, you just can't bypass the screen to navigate. I can only navigate on battery power. I don't think it's dust on pins.
  • kazi-hotmail May 11, 2010
    I had the same problem. Perhaps I can help. Please email me
    the detailed steps you have taken until you got stuck. My email is kazi at
    hotmail dot com.
I bought a Garmin
Posted on Aug 07, 2009
Thinks car charger is a usb adapter
I feel you might have one of two faults here ether or so do not shoot the messanger.
1. Bad card chrger
2. Failed chrging element inside (usb controller)
I work on these things for people to have enought expertise and working knowledge to let you know what it could be and for you to make the choice to check it. Do this
Plug it into a computer if it does charge replace the car adaptor you be glad you did. If it does not charge on the usb take the unit it for repair. Now if this is under warranty take it in to have it repaird.
Thanks for using fixya.com please do leave postive feeback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | Magellan Maestro 3225 Car GPS Receiver
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
or buy the port here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3225 says it's plugged into a PC
Can you use it as a regular GPS when charged? If yes, charge it offline and use it only when charged. If not, I had the same problem. Please email me the detailed steps you have taken until you got stuck. My email is kazi at hotmail dot com.
Aug 27, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3225 usb charging
Go to system setting and you will see the charging icon animation and displaying battery strength.
May 24, 2009 | Magellan Maestro 3225 Car GPS Receiver
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
Nov 10, 2008 | Magellan Maestro 3225 Car GPS Receiver
Need to update the maps on the gps magellan maestro 3225
I need to update the map on my 3225 Magellan Maestro, can anyone help?
Sep 28, 2008 | Magellan Maestro 3225 Car GPS Receiver
Charge Problem
Hello guitarman249,
It sounds like a bad battery. Theoretically, it could be the charger but if the red light on the charger still comes on when the unit is plugged in then the battery is the more likely culprit. The only way to really know for sure is to try charging the unit with a different cable, such as the USB cord used to connect the GPS to a computer. The GPS should charge when connected to USB. If it doesn't, then it's the battery.
Like most GPS receivers, the battery on this one is not replaceable by the user. If you do determine that the battery is causing the problem you will need to contact Magellan tech support to arrange a battery replacement.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 02, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 3225 Car GPS Receiver Logo
343 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
