Question about Dishwashers
Fisher Paykel displays F1 error and will not stop running. How can I reset to get it back to normal service or turn-off the machine while waiting for service.
  • 56 Answers
F1 is the flood switch theres a moisture sensor on the bottom and leaves the pump nrunning
Posted on Jun 30, 2009
  • 4 more comments
  • ssclifford Jun 30, 2009
    f1 is the flood switch theres a moisture sensor on the bottom and leaves the pump nrunning
Fisher paykel displays F1 error and will not stop running, How do I reset.
Posted on Jul 03, 2009
How do I stop the F1 error even after assessing there is no water in the bottom tray and dried it with hair dryer just in case
There should be F1 on both displays. "If power fails to the bottom tub it will cause the top tub to go F1. Test heater plate." (from the service manual).
If there is F1 on both displays it could be a faulty flood switch or PCB.
Jan 30, 2015 | Fisher and Paykel Dishwashers
F1 keeps flashing and machine wont turn off. I have flipped the breaker so it stops, but what is the fix for this F1
Flood error.
lean back at 45 degrees and let the water out of the spill tray.
Try again, if it fails >> call a service agent
Oct 17, 2013 | Fisher and Paykel Dishwashers
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
Soapy water caused machine to stop f1 switch came on?
I am assuming you turned off the mains power. Turning the power back on should reset the machine.
May 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Its showing f1 error when machine is turned on
too have had this problem and looking at fixing it. I found a google cached thread on a different website that may assist you:
http://72.14.207.104/search?q=cache:B0R4JOEfwBAJ:serviceeveryday.com/forums/showthread.php%3Ft%3D124%26goto%3Dnextoldest+fisher+paykel+fault+code+reset&hl=en&gl=au&ct=clnk&cd=8
(copy and paste the entire line in your address bar)
Using the thread above, this is what I'll be trying tonight:
1. Check the drain hose and make sure there is no blockage. Also ensure the hose isn't raised too high as water might run back to the machine.
2. Check the port hole and make sure it's big enough for drainage. If not I'll be either bashing it or drilling it out to make it bigger.
3. Reset the machine by powering off the breaker for a few minutes. Turning the power off at the wall doesn't work.
4. Last option would be to use the advice from Fisher & Paykel themselves and leave the door ajar for 5-7 days.
I'll let you know how I go. Anyways, hoped I've helped and good luck!
Mar 15, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
954 people viewed this question
Top Dishwashers Experts
