Question about JVC RM-C18G-1H Remote Control
Our remote stopped working. RM-C203G. We changed the battery but it still is not working. Are there programming code to try to reprogram the TV remote?
SOURCE: TRYING TO PROGRAM MY NEW SONY RM-YD024 REMOTE
Try these
For Direct TV:
00099, 00247, 00392, 00566, 00639, 00749, 00819, 01076, 01108, 01109, 01142, 01377, 01392, 01414, 01442, 01443, 01444, 01609, 01639, 01640, 01749, 01856, 20739
For Panasonic Satellite receiver:
00247, 00701
You can also look here:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMYD024
Posted on Dec 23, 2008
SOURCE: Programming Code for Sony RM-VL600 Universal Remote
http://www.xdiv.com/remotes/
Posted on Jan 02, 2009
greenspan
  • 1734 Answers
SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Posted on Feb 22, 2009
jdvillanueva
  • 2098 Answers
SOURCE: Yesterday my JVC TV remote quit working when I
Checked the battery terminal of the remote control for corrosion build up, erase it using a smooth sand paper or a blade.
It must be check for bad solder joints inside mostly crack joints in the infrared emitter and battery terminal.
To confirm if the remote control is working fine after the above solution has been done, point the infrared emitter of the remote to your cellphone camera, while pressing any button key on the remote, you will see the flash of the infrared emitter. Watch this VIDEO for more info.
Let me know if the infrared flash on the camera.
Jdvillanueva
Posted on Jun 09, 2011
  • 879 Answers
SOURCE: How to program JVC Remote RM-SXV067A Remote to TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Jun 20, 2012
CHUNGHOP RM 139ex FOR LG TV
The best universal remote is the Logitech Harmony remote. It never gets outdated and will work on any tv. You use their website to program the tv and any other component you have hooked up to it. For example: If you get a new bluray player to replace your old dvd player you simply log back on the website, connect the usb cable that comes with the remote and reprogram the remote.
Mar 20, 2014 | none CHUNGHOP RM-139EX Universal Remote...
Black bar on the screen
This is not the fault with remote control. Check your TV. Contact any experienced service technician.
Jan 20, 2013 | JVC RM-C203G Remote Control RM-C203G-1C
My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Jun 03, 2009 | LG 32LB9D TV
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
RCA RCR311B Control Problem
Download the user manual from here:
http://www.retrevo.com/s/RCA-RCR311B-Universal-Remotes-review-manual/id/402ci569/t/1-2/
Click on the PDF download in the product summary.
Cheers
Jun 02, 2008 | RCA RCR311B Remote Control
Remote
If you have the original remote, it does not need any reprogramming because the Sony code will be the first one even if you change the batteries.
Try pressing the TV key on it if you have the RM-Y185 remote, also try to move the switch to the AV1 position.
Mar 28, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Need to reprogram remote
Trying to fine GE Remote for Model RM 24908 need the Codes to program the TV
Feb 19, 2008 | GE RM24906 Remote Control
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Program universal remote
check remote first, and replace ir ditector in the tv...
Sep 28, 2007 | Orion1934 19" TV
JVC RM-C18G-1H Remote Control Logo
179 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
