Question about Canon Cameras
My Canon Digital Camera Powershot A 95 has no image to take pictures
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jun 30, 2009
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
After taking pictures on a full screen, suddenly my camera appears to be set showing a black frame below/above for horizontal, left/right for vertical. I can no longer return to the full screen... wh
You've apparently switched your camera to the widescreen mode. To switch to another mode, follow the instructions under "Changing the Recording Pixels (Image Size)" on page 65 of this manual.
Mar 23, 2013 | Canon PowerShot SD1200 IS / Digital IXUS...
I want to copy pictures from my PC back to my camera but it won't let me do it. How can I do this?
No it is not possible to transfer pictures from PC to your CANON as the image quality changes. Yes you can transfer pictures from CANON to your PC (because it will auto adjust the image quality by windows). The best solution is to remove the SD card from the camera and put it on your PC. If the camera had a built in memory card...use the software that comes when you by the camera. Install it then transfer between PC-CANON and CANON-PC is possible.
Mar 09, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
How do I erase "protected"
Unprotect them first. While viewing the picture, press [MENU] and select "Protect". Full details are in the "Protecting images" section of the manual (page 100 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/6/0300003266/01/PSSD1300IS_IXUS105IS_CUG_EN.pdf
Dec 13, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Jan 14, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Cannon PowerShot A80. Pictures come out with red tint and what appears to be horizontal lines across complete image. However, record video without problem.
If camera shows previously taken pictures in playback mode and does notshow live view to take fresh pictures then it is ccd imager chipfailure. CCD imager will be replaced in your Canon A80 camera.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Oct 27, 2009 | Canon PowerShot A80 Digital Camera
"lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
Oct 11, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
My A95 Powershot pictures all look pink
Its known problem of ccd imager in Canon A95 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Thanks.
Jun 20, 2009 | Canon PowerShot A95 Digital Camera
All black image
this is the problem with ccd .its a manufacturing defect.canon replacing the ccd free of cost.contact canon
Apr 28, 2008 | Canon PowerShot A95 Digital Camera
Cameras Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
