Question about Kenmore Washing Machines
Washer dont spin - Kenmore Washing Machines
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How do I set spin only cycle
with alot of LG washers they dont a have a spin only cycle, i dont know why they dont but it confuses alot of people, if so you should see a button that allows you to change the spin speed what you do is when you turn it on DO NOT select a cycle just press that spin speed button then press start and it will do a spin only cycle :)
Oct 11, 2014 | LG Ultra Large Capacity White Front Load...
Washer spins on delicate only. Won't spin on
Hello, Does it sound like its spinning in regular and just not spinning? If So You may just need to replace the belt. Also this unit the motor pulley would melt and break. Lean the unit back and you can see the belt and pulley. Hope this helps and please dont forget to rate me. Thank You...
Jun 08, 2011 | Maytag Atlantis MAV7551 Top Load Washer
Spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
It fill the tank but dont spin
first check the lid switch .. that the lid is closing and hitting the switch... you should hear a click.
Sep 19, 2009 | Kenmore 24902 Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
16 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
