Question about Kenmore Refrigerators
Refrigerator model #596.65232402 won't cool. freezer seems to be fine
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
  • 62 Answers
SOURCE: Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
first off unplug ref and melt the ice with a blow dryer.then check your defrost circuit,it is easier to check with the ice gone.
Posted on Dec 22, 2008
  • 31 Answers
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
kram26
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
"I have a kenmore coldspot model 106.54382300. The freezer is working fine, but the refrigerator doesn't seem to be cooling. We just bought this used and it has worked fine until tonight, when we finally...
Can you hear a small fan blowing air inside the refrigerator? It sounds like the evaporator fan has gone out and it is not transferring the air from the freezer to the refrigerator in order to cool!
Oct 09, 2014 | Refrigerators
Refrigerator not cooling
What is the complete model number of your unit?
Dec 10, 2012 | Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Refrigerators Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
