Question about Sharp Aquos LC-20B2U 20 in. LCD Television
MY POWER KEEP GOING OF SHARP lc-20b2ua
MY POWER KEEP GOING OF and when i un plug the TV it it comes back on and then go back off what is going on SHARP LC-20B2UA
I have the same problem. I fixed it for about 3 months by wrapping duct tape around the large pack midway in the cord (where the wall plug and TV line plug in). But, it started up again this week. I can't get the "box" open either, but that is where the problem is. Mine is mounted to the wall, so no one ever touches the cord. I'll let you know what we find when we get it opened.
Posted on Dec 29, 2010
  • Jesse Walters
    Jesse Walters Feb 22, 2011
    I found there is a dead resistor somewhere that is in line with the ground side of the inverter coils. So If you get sound but no picture (or it goes almost immediately dark after power on, it is sensing a voltage surge or drain. I put a 12 v dome light bulb in line with the common ground from one coil to chassis to restore a completely dead screen and all bulbs are now on with one coil thusly semi-grounded.. Yes - weird. I studied the mobo and supply all 4 13v connector pins from one standard spliced wall wart.
My Sharp TV LC-60LE755U using power board DPS-204EP-1-A is dead. Does anyone have test points where I could check the voltages on the board?
hi you need to test for 3.3v going to the mainboard and then test it coming back from the mainboard if it's low it will not switch the tv on, thanks
shaun
Feb 27, 2017 | Sharp Televison & Video
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Mar 06, 2012 | Sharp LC Televison & Video
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever...
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
Jul 28, 2010 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Power on TV went out and it will come back on.
Check for busted fuse inside your TV, so you can switch it back on. So, open it up. Follow the power cord going inside your TV. The fuse is just near to it. Have it replaced, and have it carefully clean free from dust using 1/2 inch paint brush. Put the case back close, and plug it back to your outlet. Switch it on. Hope this
help you, and thank you for casting your vote.
Sep 22, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sharp agous .. no power
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Aug 30, 2008 | Sharp Aqous LC-26D5U Television
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
Apr 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
712 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
