Question about Coleman Powermate 60 Gallon Air Compressor
I'm considering purchasing a pre-owned Coleman Piwermate 60 gal air compressor, but the selled doesn't know the SCFM@xxPSI info. Any help would be greatly appreciated.
  • scottihicks Jun 30, 2009
    Thanks for the help. I'll ask the seller if he can give me the info.
    Does anyone know where I could find the answer otherwise?
  • 2,418 Answers
It is posted right on the tag of the particular compressor. Should be any way.
Posted on Jun 30, 2009
  • John Fourteen Six Jul 01, 2009
    Google the , (Coleman Powermate 60 gal air compressor) Ck all sites that sell one, and read the spects
I am wanting to know what this one is worth. "27 gal, 5 HP, 115 volts oil free operation. Coleman power mate black max air compressor?
One sold on ebay for $125.00. It is made by sanborn. Sell locally
freight charge will make to expensive
Apr 19, 2017 | Coleman Air Tools & Compressors
Im going to buy a compressor ! What is the min scfm comp that will run this tool for small jobs on my car?
Hi and welcome to FixYa, I am Kelly.
Air Tool consumptions are based on 15 seconds per minute (25%) of tool use.
Usage rates refer to the total time that air is flowing through the tool. If your applications result in more extensive usage, calculate air tool requirements as
follows.
(25%) 15 seconds = rated scfm x 1
(50%) 30 seconds = rated scfm x 2
(75%) 45 seconds = rated scfm x 3
(100%) 60 seconds = rated scfm x 4
Your impact wrench is rated a 8 CFM Cubic Feet Per Minute Usage
SCFM is Standard Cubic Feet per Minute (pre-compressed air volume)
I would be more concerned that the plumbing from the compressor tank could support the 8 CFM required by the 1/2" Impact. Remember the Air compressor will recover the pressure loss regardless of size. The only problem your going to have for "small jobs" is if you use too small of an air line to supply the impact wrench you are not going to get the full torque that it will produce to the drive head. In other words... a 1/4" supply line or 1/4 fittings anywhere in the system just isn't going to cut it even at 120 PSI. If you have the patience... a 5 gallon tank compressor that has the output volume required should be all that you need. I have been a mechanic over 4 decades and rarely have to use a 1/2 in impact for very long. Examples of 1/2" vs 3/8" useage. Wheel nuts, crankshaft pulley center bolt, some starters, steering, suspension and rear end parts. Other than that a 3/8" Impact works great.
One other thing you can do if you have an Air-Peen portable tank (with added fittings) is to add that in line with your output hose when your using the impact wrench so that you have longer use times.
I know this does not answer your what SCFM compressor is required question but it will resolve your needs. I just can't see telling someone that is a "small jobs" user to buy a larger compressor when really all they need is more volume for a brief period of time. The re-plumbed 1/2 inch output / in-line Air-Peen tank is a much cheaper and reasonable work around and you can disconnect that tank when your not using the impact wrench.
Lastly... if your inpact wrench has a SMALL male air fitting everything above will be a waste of time. You have to get that volume into the tool without restriction so that the rool will work properly for you.
Thanks for choosing FixYa.
Kelly
Mar 09, 2011 | DeVilbiss Excell ET501 12" Impact Wrench
Compressor doesn`t stop and only goes to 60 pounds
Your compressor goes on and off based on the pressure. If it only goes to 60 # and no more, I would say it is worn out. The rings most likely. It can be repaired ... but before you go get the parts, consider that if the rings are worn, so too is the rest of the machine ... Consider the price and time to repair your machine and compare to a new machine before you get started.
Nov 01, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Manual for coleman vp201 air compressor
THE PSI RATING IS 70-100PSI. I WASN'T ABLE TO FIND THE SCFM AT THEIR WEBSITE. NO MANUALS AVAILABLE AS OF YET.
Jan 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
3 gal 2.4 scfm@90osi E100730
check and see if the air is blowing through the pop off valve...little round plug with a ring hanging off of it. Also, check and see if the regulator has been turned up to a high pressure....air may be blowing through the regulator
Jul 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Apr 14, 2009 | Air Tools & Compressors
I need a switch and guages
WW Grainger- they are everywhere and carry just this typ of control, also on line, You will need to open an account with them in a business name. Or find the product on their web site nad search the number on the web for somone that will sell it to you.
good luck
Good Luck
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
Wires on Compressor motor disconnected.
Some compressors come unwired so the purchaser can wire for 110 or 220 by their choice. This I would think would be possibly your case. Was this purchased new? In any case, here is a site where you may be able to obtain a manual,
http://powertool.manualsonline.com/manuals/mfg/coleman/coleman_air_compressor_product_list.html
and here is one with a similiar description but a different brand compressor.
http://www.thestuccocompany.com/maintenance/240-volt-air-compressor-wiring-advice-from-Campbell-Housfeld-25469-.htm
hope this helps. copy and paste short cut, in case you may not know, highlight text you want to copy by holding down left mouse button and moving pointer of mouse over text desired,while cursor is still over the high lighted area release left button and right click mouse, select copy, then put cursor in the box you want to paste, right click and select paste
Nov 25, 2008 | Coleman Powermate 60 Gallon Air Compressor
Coleman Powermate 60 Gallon Air Compressor Logo
228 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
