Question about Black & Decker AS175 Iron
My AS175 does the opposite! It constantly turns itself off!
Even when I am using it.  This is the second time that a Black and Decker iron has gone wrong in under a years use.  Great product, highly unreliable.
  • martin_playf Jul 05, 2009
    thanks stonephoenix
    I called tracked down customer service, which was some other company besides Black and Decker, but deal with B and D warranties. The name escapes me, but I'm sure you know who I mean. Regardless, I have cut off the plug of the iron and sent it off.
    Thanks for taking the time to respond.
    M
    President:
  • 563 Answers
I work for Black & Decker customer service. Our phone number is 800-231-9786.
I regret to here that you're having problems with your iron. However, the iron has a one year warranty, and if you call the above number, we'll be more than happy to send you a replacement. And, no, we will not ask you to send the old iron to us.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
Please get rid of this iron! I had one and it caught on fire completely destroying my home and my belongings. I contacted Black and Decker and they asked me to SEND them the iron!! Helllooooo....it burned up...there's nothing to send.
PLEASE DO NOT BUY OR USE THIS IRON!!
Posted on Jan 04, 2010
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
Why steam iron won't heat up
if there is no light or heat even when the thermostat is switched to the hottest setting then assumption is that the iron is defective.
with the iron not plugged in check the cable and see if it is worn or kinked or cut. look for any burn markings on the plug. if the iron is some years old it may also be that the element has burnt out. this happens more often in areas where water scale is high.
I hope this was useful.
May 12, 2014 | Applica Black And Decker F975 Steam Iron
I require a manual for an iron I just purchased yesterday. Cat. No.AS210 Tyype1 Black @ Decker. I am 76 years old and over the years used many of your products. I just want to be sure, and a manual
http://www.managemylife.com/mmh/owner_manuals/70113/Black-Decker-Iron-AS200-AS210-AS225-AS250798
Copy and paste the above info. and wait a few seconds for the web page to fully load. The manual will be ready to download once the page is fully loaded.
Jan 31, 2012 | Irons
My Black and Decker Steav Xpress AS 685 will not heat properly.
Please call Black & Decker at 800-231-9786 and request to speak to a supervisor. If you tell them that you aren't going to purchase another Black & Decker product again following this issue, they will help you.
Please post a comment if you need additional assistance so that I can help you further
Aug 05, 2009 | Black & Decker Steam Xpress AS250 Iron...
How do i clean the plate of the bernina pro glide iron, it sticks when i am ironing.   my mistake, called Bernette ProGlide Plus  Model #1660 (an older iron, was my mothers, but still works)...
I have used the cleaner that is used for the corning cook tops (smooth cook top range cleaners).. It has worked great on mine...Hope this helps.
May 18, 2009 | Irons
Iron reads error
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron is not heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Mar 29, 2009 | Black & Decker D2010 Iron with Auto...
The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 11, 2008 | Black & Decker D2020 Iron
Melted material on face of iron
Yes- I had the same problem and could not clean it off. It was a plastic sticker that melted on the iron plate- placed there by the manufacturer. I called Customer Service at Black and Decker, and after all their solutions failed- they sent me a new iron. But this one leaks water terribly to the point where the clothes are soaked after only 1 or 2 articles are ironed! I am beginning to lose faith in Black and Decker products.
Dec 24, 2007 | Black & Decker D2030 Iron
Black & Decker AS175 Iron Logo
110 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
