I have a mp170 printer with an error message waste ink absorber is full. I have removed and ultrasonically cleaned the pads and also cleaned the surrounding area. I cannot reset the printer to overcome the error code.
  • sohara6 Jul 07, 2009
    Unfortunately your solutions did not work it seems cannon are keeping the fix for this problem in house. I have tried all your suggestions including the download one which definitely did not work. The program did not work so I gave up gave it to a Cannon agent and now it is fixed for $49.95 Aus. I did this after speaking to a Cannon problem advisor so it seems Cannon have managed to keep problem solutions in-house pretty much like what is happening in the Automotive industry in Australia.
    Good Luck in the future but it seems you are only guessing
    Regards Steve O'Hara
  • 13,433 Answers
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
If that doesn't solve the proble follow this page to solve the problem:
http://resetters.blogspot.com/2008/10/reset-waste-ink-counter-canon-mp150.html
After you have used the tool and reset the printer, if for some reason its not working and you did everything correctly? Try again - if the problem is still not solved follow the other resets I have listed for you below:
Try these resets:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The
indicator should be orange.
6: Press Power to set data.
if that doesn't work try the next one.
1. RESET WASTE INK COUNTER Reset the counter if the waste ink level is
50% or
less; else replace the waste ink absorber and reset the counter. 1. Turn the
printer off. 2. While holding down the RESUME button, press the POWER
button. 3. Continuing to hold down on the POWER button, release the RESUME
button. 4. Press the RESUME button twice while the indicator is blinking. 5.
Release the POWER button. 6. Once the indicator has stopped blinking, press
the RESUME button 4 times. 7. Press the POWER button.
2. RESET THE EEPROM The EEPROM must be reset when the logic board or
waste ink
absorber is replaced. 1. Turn the printer off. 2. While holding down the
RESUME button, press the POWER button. 3. Continuing to hold down on the
POWER button, release the RESUME button. 4. Press the RESUME button twice
while the indicator is blinking. 5. Release the POWER button. 6. Once the
indicator has stopped blinking, press the RESUME button 3 times. 7. Press
the POWER button.
Manual Reset procedure Waste Ink Tank for Canon Just Follow this step to reset waste ink tank full:
1. Start with printer on, press aadditional functions, Scan, Copy, Scan. Now you should be in service mode.
2. Select Test mode which is like the last available selection
3. Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
* The menu will now say EEPROM Clear
* Select Ink count which is option (0) and press set
* Then press Stop/Reset Followed by the power button and then wait for it to restart.
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times...
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
1) Start with the power off
2) Hold down the ON/OFF button plus the RESUME button at the same time.
3) Keep your fingers on both bottons and THEN let go of the resume button.
4) Then press the resume button twice
5) And then let go of the OFF/ON button (which you have been helding down while pressing the resume button twice).
6) Then,first press and release the resume button 4 times
7) And then the power button 2 times after this.
The printer should now be okay and the lights will return to normal (solid green only).
Posted on Jun 29, 2009
  • Ekse Jun 29, 2009
    Here is one more:
    MP170 (5b00) Ink Tank Full Error Reset
    1,power off.
    2,hold stop/reset ,hold ON/OFF
    2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
    3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
    4,then push power twice, quickly
    5,power off and power on.
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink full?
GET YOUR PRINTER SERVICED AND CLEANED
VOTE AND GIVE ME ALL THUMBS
PROUD TO B AN INDIAN
AND PROUD TO BE A PUNJABI
Jan 28, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Received message ''the waste ink absorber is full'' What can I do?
You will have to replace the waste ink pads. There should be two of them on the right under the print head in rubber containers. It could be a messy job though. I think the pads on that printer has a metallic strip for detecting full condition. So you can't reuse the pads even if you clean them up.
Sep 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I am getting an on screen message
The waste ink absorber covers the whole bottom of the machine, under the printer. It is difficult to change, and you have to get into the diagnostic mode to reset the error. A shop repair...
Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Mp170 waste ink absorber full
The waste ink absorbers on this machine are under the print engine and cover the entire bottom of the printer. You have to have access to the diagnostic program on the printer to reset the error codes.
Jun 29, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
MP170 ''Waste ink near full.'' How do I clean it and where is it lo
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
All Best: Pineworks
Nov 11, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink pad full error message
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Aug 04, 2008 | Canon PIXMA MP170 All-In-One InkJet...
63 people viewed this question
k24674
jasbo
jasbo
