Question about Sanyo DS25390 TV
Buzzing in TV is from part sdt sh 112dm. will changing the part quiet the buzz?
C622 is the real problem. It is a 470 uf capacitor filtering the power to the blue relay. Radio Shack sells it for $1.29 part number 272-1030. make sure you observe polarity when you replace it. In other words, the side marked minus goes on the negative side. Check the markings on the old capacitor and replace it the same way with new one. The new capacitor has a higher voltage rating which is even better.
Posted on Jul 29, 2010
Kef psw 1000.2 buzzing
The internet is awesome, I just followed John Bloomfield's advice above and my 10-year-old Kef 1000.2 sub-woofer is back in action!
Sep 19, 2013 | Audio Players & Recorders
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a ?buzzzzzz? from the back of the TV. As I worked it for more then 5 hours I...
I'm pretty sure that the buzzing sound is a not normal thing for an LCD TV. I sell Flat Panels during my spare time and it should be as quiet as a CRT types. It is more likely a defect and you should return it ASAP.
Hope this helps.
Oct 23, 2010 | Televison & Video
My TV is buzzing nonstop. What will fix this??
is it buzzing when turned off or just on and is it buzzing durning bright scenes or just buzzing bright scene change buz is an If problem . in todays set , the best thing to do is change out the signal board sometimes
it could be a transfomer laminate buzz in the case your best bet would be to hire a tv tech to take a listen
Nov 20, 2009 | Akai PTH5498 54" Rear Projection...
Buzzing
The SDT-SH-112DM is a SPST Form-1A relay. It was hard to find, so I went to Radio Shack and bought a similarly sized and rated relay that was a DPDT (also from OEG). broke off the NC pins, joined (soldered) the switch source lines & removed the unused NO pin so it would fit in the drill holes... works fine!
May 26, 2008 | Sanyo DS25390 TV
Sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
Samsung LE26R74BD plasma sreen tv sound problem
To Fix.. The Buzz.. The noise comming from one of the Board Inside. Open it and see..Or call a tech..
RezaKhan
Apr 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Buzzzzzzz
Hello to all you buzzers, I have the answer to your problem. First this is what's happening. The buzzing is coming from the power relay. It vibrates at 60hz because the power supply filter capacitor is not doing its job hence you have a rough d.c. pulse going to the relay.To solve the problem remove back of t.v. slide circuit board out (you will have to disconnect white wire from degauss coil,located on left front) look for a blue box approximately 3/4"x1 1/2" this will be the power relay. Now look for capacitor location #c622 near the relay. This capacitor should be 470uf 25v. Remove and replace with 470uf 35v capacitor, connect white degauss wire temperarily put back on and give it a spin. Hope this solves all the buzzin,robert
Jul 12, 2007 | Sanyo DS24425 24" TV
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
Nov 23, 2006 | Panasonic TH-37PE30 37 in. Plasma...
Televison & Video Logo
250 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
