Question about Hughes HRMC11 Remote Control
PROGRAMING MY HRMC-15
HOW DO I PROGRAM MY HRMC-15 REMOTE TO ALLOW ME TO PUT IN MY CODE TO CONTROL MY TV INDEPENDENTLY?
4 Suggested Answers
SOURCE: lost owners manual and need to program remote to Panasonic
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
Posted on Feb 07, 2009
BigLou1958
  • 104 Answers
Link for owners manual
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
Posted on Oct 22, 2007
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
I have a hughes remote hrmc-15 and have a insignia new television however tech i called only solution to connect the remote to the tv was to buy a new remote do you have a code for this tv that will w
026,018,072,081,049,024,000,038 are the codes to check with Insiginia brand TVs. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 27, 2013 | Hughes Directv HRMC-15 Remote Control
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
Have HRMC-15 remote ned the codes for sanyo tv
Sanyo tv codes for use with the HRMC-15 are 007 020 053 057 082. Also, you can do a search on the computer and download the Hughes owners manual.
Jan 15, 2010 | Hughes HRMC11 Remote Control
Help! Can't program remote!
from the book: this is for the HRMC-5 may be the same.
Code Scan if you don't know the code.
Keep remote aimed at the device you want to control. during the programing, the device will send out a "power" command for the device being programmed.
While holding down the device key(i.e., TV) that you are programming, press the "Mute key for one full second. then release the keys. the device key should light up and stay lit. if not, repeat the process.
repeatidly tap the channel up key to step through the codes, sending out the "power command". may take some time, many codes. when device shuts off, you have found the code. If you inadvertantly went past the code, that responded, you can press the channel down key to go back. press the "power key to verify you havent missed the code. In order to lock in the code, press the device key again. the remote will remember the code till you re program it.
Mar 27, 2009 | Televison & Video
How to program remote for tv and codes
dont have codes for programing HRMC-5 (11), I HAVE A SYMPHONIC tv
Jan 02, 2009 | Hughes HRMC11 Remote Control
How do I program my HRMC-9 to a new computer? I lost the directions.
I have a HRMC-8 remote. Cant find the manual and need to program for a different TV?
Aug 16, 2008 | Hughes HRMC9 Remote Control
Lost owners manual and need to program remote to Panasonic
Hold down Select and Mute until the tv light flashes. The enter the code and press Select.
May 12, 2008 | Televison & Video
3-in-1 remote 15-2147
Have you tried these codes?
Toshiba TV codes: 0154, 0156, 0060, 1945, 1935, 1918, 1704
If your TV is a TV/DVD combo then use code 1935
Please follow "Programing a Device" on the product manul.
Feb 18, 2008 | Radio Shack (15-2147) Remote Control
Will a HRMC 8 Program to a dvd/vcr combo by Toshiba?
I HAVE A TOSHIBA TV AND I WANT TO PROGRAM MY REMOTE TO WORK BOTH. THE REMOTE IS A HRMC-B
Dec 15, 2007 | Hughes HRMC11 Remote Control
4. Aim Remote at TV
8. ENJOY !!!
Oct 22, 2007 | Hughes HRMC11 Remote Control
Hughes HRMC11 Remote Control Logo
838 people viewed this question
Top Hughes Televison & Video Experts
jason
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
