Question about Allegro DVD/VCR ABV511
Comcast Digital Conversion box (cable TV)
I am having problems taping a TV program after I added the Comcast Digital Conversion box. Everything worked fine until I added the Box. I can tape only on Channel 4. The VCR is an Allegro ABV341. I am only using coax from the wall to the Box, from the Box to the VCR and then to the TV. Any suggestions? (I only use the VCR portion of the Combo VCR+DVD unit).
Gerrit
  • Anonymous Mar 26, 2014
    How do you program a RCA RCR312WR to a Allegro DVD/VCR device
  • 49 Answers
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Posted on Jun 29, 2009
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
We have Comcast cable and are experiencing pixelation problems. This only happens between 9 a.m. and about 6:30 p.m. This happens on both an HDTV and an analog TV. Both TVs have cable boxes as well as...
Entre em contato com a sua operadora de tv a cabo. Isto e muito comum quando o sinal e trocado de analogico para digital. O problema e da operadora.
Dec 13, 2010 | Vizio P42HD Television
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
PS3 randomly mutes my TV, Mostly on DVDs
it sounds there is a lose connection inside the ps3 somewhere not sure though hope this is any help to you.
Feb 07, 2009 | Sony Playstation 3 (PS3) Console
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Durabrand DU1901 digital ready?
The digital Cable conversion only effects those who still get their TV channels through an antenna or rabbit ears. If you get it through a cable provided like Comcast, you SHOULD be fine. For more information, look at the FCC website.
Happy viewing :)
http://www.dtv.gov/consumercorner.html
Jan 05, 2009 | Durabrand DU1901 TV
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
876 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
ray gallant
Vernon Taylor
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
