Sony TV won't turn on :-(
Hello there, I have a Sony kv-40xbr800 and when you try to turn it on it sounds like it's going on, but instead the red standby light just flashes. I have seen SEVERAL other posting on Google where others are having this problem with the same tv. Do you know if there is a way to fix this?
  • Anonymous Mar 31, 2008
    Had similar issue with my Sony. I tried unplugging the TV for 2 days. When I plugged in and turned on, it worked. However, my wife shut it off with the TV clicker, instead of just shutting off the cable and it has been 3 days and it won't come back.
    If you get it to work, try not to shut it off from the TV clicker.
  • urinated Feb 24, 2009
    Had my Sony for two and half years would not turn on and stby light flashes six times. Replace 5 volt reg on H card. $300+ to repair. 1 year and 1/2 later same Tech replaced same component but it did not repair set. Said I needed
    to replace H card est cost of repair $600, that's when TV became a 230 LB desk. Replaced with Samsung 1080p 40" LCD flat panel. Great picture, great contrast ratio. Sony was model KV 36HS510. It was only 1080i but had a comparable picture. Paid $1375.00 for TV new and got only 2 and 1/2 years service. Not acceptable money output per use ratio. Sony needs to address this issue or it will affect sales at some point. Quality is not what it used to be. Had nothing but Sony's for 20 years will not buy another.
Our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Posted on Mar 11, 2008
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony 40" tv kv-40xbr800 pwr/stanby lite blinks 7 times no power or sound
hello shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Dec 27, 2009 | Televison & Video
I have a Trinitron KV-40XBR800. Won't come on.
the indicator lamp flashes a determined amount of times then there is a pause, then lights the same amount of times again, by what you describe there is a power supply or a deflection circuit problem.
Jul 28, 2009 | Sony Televison & Video
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron KV-40XBR800 wont turn on
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-40xbr800
Exact same problem. KV-40XBR800 wont turn on, blinks six times. I am in the process of changing both Ic's part# MCZ3001D with part# MCZ3001DB. Ordered them frm ebay and waiting for the new parts to arrive.
here are the pictures of both chips and after i removed them from the d board.
As soon as i receive the new ones i will put them in. I can't wait to see what happens and i wanted to say thanks to all of you out there for putting this thing up. Thank you very much.
Nov 05, 2007 | Sony KV-40XBR700 40" TV
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
