Home | RCA | Spirit Of St. Louis Radio/Cassette/CD Boo... | I have a jukebox tha...
RCA Spirit Of St. Louis Radio/Cassette/CD Boombox
Problem for RCA Spirit Of St. Louis Radio/Cassette/CD Boombox
I have a jukebox that stopped playing radio, cd
By claudia_cisn on Jun 29, 2009
I have a jukebox that stopped playing radio, cd and cassette? any recommendation on where or how to fix it?
Sponsored Links
Solution #1
posted on Jun 30, 2009
Somewhat Helpful)
ronaldo_ross
Rank: Wiz
Rating: 84%, 229 votes
This is a power supply problem. First check for a blown fuse where the AC cord comes in to the circuit board. Try to put another fuse if its blown with same rating. If it blow again then there is a semicondutor that has failed. Semiconductors fail by conducting current on both direction therefore creating a short. Example of a semiconductors are: diodes, transistors, regulator packages, chips etc. Transsistor would have three pins. Diodes are usually cylindrical shape with a color band on one end, and has pin on both ends. Chips, and are also semiconductors, but rarely goes out. Thats because most chips run on very small current. The rule of thumb is the bigger a semiconductor device, the more current it operates on, and therefore more likely to naturally fail. So if you were to test one of these components. You would use a multimeter, turn the dial to select "diode" and do a go/no-go test. Meaning you would see if there is contituity on only one direction. Now in that mode, the meter actually display "voltage drop" semiconductors usually have 0.4 voltage drop across one direction, give or take a few fraction of a volt. The other direction there is almost no voltage drop. Thats because it is not suppose to conduct the other way. If you suspect a shorted out diode, or transistor in the power supply, take it out of the circuit, using a soldering iron, then measure it one more time to confirm. If it was bad, note the number on it,and hopefully it is still readable, and replace with the same kind, or one the has the same characteristic.
Was this helpful?
Yes
No
Popular Solutions for RCA Spirit Of St. Louis
Questions and Unsolved Problems for RCA Spirit Of St. Louis
Do you recommend RCA Spirit Of St. Louis Radio/Cassette/CD Boombox?
Answer
Answer
I have an RCA Spirit of St. Louis Radio/Cassette/CD Boombox. The CD player has stopped working. How... (More)
Answer
I have a model 543.367 Gershwin and lost my instructions. How do I set the clock? Thank You
Answer
my record player does not work because the belt has slipped off of the pulleys and i dont know how... (More)
Answer
the feed wheel or gear s missing for the cassette player rendering this unworkable is this fixable
Answer
i have a spirit of st louis boombox cd player isn't working i used a general adapter becaue i... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA Spirit Of St. Louis...:
Top Boombox Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Boombox Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
