Question about Acer Aspire 5580 Notebook
My Arcade stop Loading the Menu Screen
When I load the program, the Acer Arcade screen pops up, but it will not let me go to the home screen (menu Screen), where you can select: movies, Pictures, etc.
My acer aspire one zg5 got the blue screen. after loading the windows, it will stop then flash the blue screen then restart again and again. what will i do? somebody say my netbook needs to reformat. but i...
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Mar 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an acer aspire 5742 laptop how do i turn my webcam on
Hi, Webcams are a great way to communicate with friends and family in other places, while still feeling like they're in the room with you. There are many different types of webcams and many different computers to go with them. So, if you happen to be a new Acer Aspire 1 owner, then follow this simple guide, and you'll be sending video of yourself to friends and family in no time Instructions
  1. Access the main menu of your Aspire 1, and click on the "Start" menu at the bottom of the screen
  2. Click on "All Programs" from the list of options, and then select "Acer Arcade Delux."
  3. Choose the "DV Wizard" option once the menu appears. Wait for the program to load.
  4. Select "Acer Crystal Eye Webcam" from the main menu of DV Wizard. Now an image capture screen will appear on your desktop.
  5. Position the Acer so you are framed clearly in the image capture screen. The webcam is built into the computer with the lens at the top of the screen, so you will have to move the entire laptop to find the right angle. Also, adjust the lighting near you for optimum picture quality.
  6. Go to the tool bar in the lower left hand corner of the computer screen to access the functions of the webcam. If you would like to record, highlight the box icon with the red dot in the middle and the word "Record" will appear over it.
  7. Click the "Record" icon to record video with the webcam. You can also choose "Pause" and "Stop" from the same tool bar. To use video messaging, access your online messenger. Whether it's AOL, MSN or any other messenger service, the program will detect the webcam. All you need to do is enable the video messaging by clicking on the webcam box.
Dec 15, 2010 | Computers & Internet
When i turn the game on, it goes to the loading screen, loads my profile, but when the message box pops up saying "syncronizing nba today. please wait..." it freezes and emits a beeping noise....
go to your Wii settings and turn off the internet so there's no way to get to NBA Today. Then the sychronize part is excluded when you start loading to play.Sorry, but you can't play online though
Nov 21, 2010 | Nintendo NBA 2K10 for Wii
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
How do I play Acer 6530 blu-ray laptop on my 42" Vizio lcd tv?
Acer 6530's are not able to play blu-ray discs without "Acer Arcade Deluxe" I had the same problem with mine and it wasn't until I downloaded this: http://www.cyberlink.com/stat/bd-support/enu/index.jsp
That will tell you if your PC can play blu-ray.
Acer Arcade is hard to find once removed from your PC. Check for it on your PC, in the programs list (Control Panel > Uninstall a program, then search the list) or search in the start menu - box at bottom called "Start Search".
If you can't find it I suggest you go back to where you bought the PC and ask them if they can provide you with some, any downloads from the internet are illegal versions. If that doesn't work, try calling Acer customer support.
Nov 15, 2009 | Acer Aspire 6530-5143 Notebook PC
I have problem starting pc after pressing acer arcade button
safemode.
1) put laptop next to you
2) press the power on button
3) keep pressing f8 repeating it fast
4) you will get a main menu
5) select "start windows normaly"
Jul 23, 2009 | Acer Aspire 5920-6727 Notebook
Black screen after Acer Arcade installed...can't find safe mode
you need to reboot then press f2 befor the computer starts because it will bring you to the option of last good configuration or like you are looking for safe mode
May 22, 2009 | Acer Aspire 5920-6727 Notebook
Can't reboot Compaq/Presario desktop, (power supply is working)
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
Dec 27, 2008 | Computers & Internet
Green start button--programs---CrystalEyeWebcam, same for Acer Arcade
Feb 20, 2008 | Computers & Internet
Acer Aspire 5580 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
